my custom harness, check it out!
Old Mar 31, 2006 | 01:43 PM
LS_DON4500's Avatar
Default my custom harness, check it out!
well i was getting sick of looking at the stock ef harness all dirty, wires everywhere, I bought my 91 si back in november with a d16z6 swap and this harness was with the swap, well its been modified by me and it looks 10 times, better, im planning on starting a small bizz making custom harnesses but thats in the near future, also hiding all the wires in the motor bay and that post will be up shortly after, almost done, starting to come around
Before
inside motor bay
some **** removed, harness out of car
New boomslang convo harness and my p28, they make the cleanest harness in my opinion,
harness after stripping tape and all the good ****
engine harness done
ill get pics up when everything is intalled and tucked, plus the motor bay needs a good cleaning, see ya in the near future with pics, thanx
Old Mar 31, 2006 | 01:48 PM
fernruffryders's Avatar
clean
Old Mar 31, 2006 | 01:58 PM
143MYVTECEF's Avatar
Default Re: (fernruffryders)
What is the multi colored extension used for that coming off the boomslang harness??
Old Mar 31, 2006 | 02:02 PM
LS_DON4500's Avatar
yes, the extention, what i like about this harness, just a connector for the vtec silinoid, vtec pressure. wires for 4 wire o2, iab and knock if u need them, harness is pimp, muwahahah! clean is the name of the game!
Old Mar 31, 2006 | 04:29 PM
K DOHC_19's Avatar
Default Re: (LS_DON4500)
What did you use to wrap you harness?(wire loom and electrical tape) I am interested because i want to do the same thing for my harness. Thats a Clean harness by the way.
Old Mar 31, 2006 | 04:49 PM
LS_DON4500's Avatar
i ran wire loom at the parts where the wires where running straight together, then taped where the sensor wires where running seperate, be sure to use good electrical tape, and tape them very tight and well! thanx for the complimants
Old Mar 31, 2006 | 04:56 PM
fast-rex's Avatar
looks clean
Old Mar 31, 2006 | 04:58 PM
LS_DON4500's Avatar
thank you, put in my car tonight now im looking for a good way to hide it all, thanx again guys!
Old Mar 31, 2006 | 05:04 PM
Tippyman's Avatar
Wish I had the patience to do all that, lol.
Old Mar 31, 2006 | 05:20 PM
LS_DON4500's Avatar
it does test it, hahaha but i think it is worth it, it looks better but in my opinion i would do a few things different, like i get a few seperate small looms of wire seperate, like i wish i woulda ran the wires for vtec, 4 wire within the whole harness, but i got them in a seperate loom, oh well still looks better but i plan on gettin my name out there in the future for this ****, like to tear the harness down, mach it up in the car then take back out and go to werk, i built this outside the car with no mach up work involved, it workes fine but with a mach up u can tell better where you can hide the ****, thanx again!
Old Mar 31, 2006 | 05:35 PM
firebane's Avatar
instead of using black tape on the loop, use black zap straps the mini ones and it'll look a lot cleaner and easier to manage.
Oil and dirt and grim will make black tape fail over time and same with heat.
Old Mar 31, 2006 | 07:52 PM
LS_DON4500's Avatar
if u know how to tape correctly u wont have that problem, tape tight, then layer it, then zip tie on ends!~~!!@@~~!
Old Mar 31, 2006 | 08:06 PM
Rywire's Avatar
Default Re: my custom harness, check it out! (LS_DON4500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS_DON4500 &raquo;</TD></TR><TR><TD CLASS="quote">
convo harness and my p28, they make the cleanest harness in my opinion, </TD></TR></TABLE>
You obviously havent seen ours then. Not trying to be rude, but ive seen that one, and there is no comparison.
Wiring biz ey? Good luck
Ryan
Old Mar 31, 2006 | 08:13 PM
LS_DON4500's Avatar
jkobd was in the car when i bought it, it was old and fuckered up so i ditched it and got this one, i was gonna make my own but i didnt, will in the future after a new swap, but hey that your opinion, ive seen ur work and most convo harnesses and i just like boomslang, opinions vary, thanx!
Old Apr 2, 2006 | 08:15 AM
LS_DON4500's Avatar
werd!
Old Apr 2, 2006 | 08:32 AM
thenick's Avatar
I would use extra protection aside from the electrical tape
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">You obviously havent seen ours then. Not trying to be rude, but ive seen that one, and there is no comparison.
Ryan</TD></TR></TABLE>
Jesus there isn't a single thread where I don't see you guys plug your company
Old Apr 2, 2006 | 09:24 AM
LS_DON4500's Avatar
Default Re: my custom harness, check it out! (thenick)
was think the same thing
efnnhatch
Feb 11, 2016 05:33 PM
yellowcanary.
Apr 18, 2015 11:47 PM
bradennicely
Apr 25, 2010 04:36 PM
