Do I need a valve adjustment ??
Old Mar 31, 2006 | 01:12 PM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
Default Do I need a valve adjustment ??
Okk i got my new jg camshaft, and the lobes are of course bigger than stock, all i thought i had to do was take my old one out lube up the new one align everything and i was good to go, but homie told me that my stock settings for valves will not close all the way, is this true i dont kno how to adjust the valves damn i dont wanna go to a shop
Old Mar 31, 2006 | 01:21 PM
tl hatch's Avatar
Default Re: Do I need a valve adjustment ?? (Evolution-93-Ex)
I think you may need to, but maybe not because the distance between the the bottom of the lobe and the shaft may be the same.
Note the use of the word "may"
http://www.c-speedracing.com/h...t.php
It's really not that hard as long as you remove the spark plugs and rotate the engine precisely. Do a search on valve adjust in archived content.
Old Mar 31, 2006 | 01:23 PM
riceburnerryan's Avatar
i would do it since youre already putting the cams in why not do the valve adjustment?
Old Mar 31, 2006 | 01:39 PM
tl hatch's Avatar
Default Re: (riceburnerryan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburnerryan &raquo;</TD></TR><TR><TD CLASS="quote">i would do it since youre already putting the cams in why not do the valve adjustment?</TD></TR></TABLE>
Yeah, what he said.
turbotime
Mar 31, 2006 06:21 AM
NETAMI
Mar 19, 2006 06:45 PM
kornerk12
Dec 18, 2005 03:27 PM
Baron55
Aug 9, 2005 03:27 PM
cornhusker
Sep 20, 2003 03:37 PM
