Suspension & Brakes Theory, alignment, spring rates....
96-00 Civic Rear Subframe Failure and Sway bars (?)
Old Mar 31, 2006 | 09:20 AM
lain720's Avatar
Default 96-00 Civic Rear Subframe Failure and Sway bars (?)
Note: There are two questions, and one request within this post.
Reason for Post: I know rear sub frame tear is a popular topic forum conversation for 96-00 Civics, but I was curious how many people in the Houston area have actually experienced their sub frame tearing/ ripping ?
Please try to be objective, and honest, some anecdotal input would be beneficial. I do realize that statistically this is a poor way to run a survey.
Question 1:
How many people on H-T.com have larger sway bars? What have your experiences been with rear sub frame strain?
Question 2:
Have some members on H-T.com experienced rear sub frame failure with larger sway bars.
If you have had that experience, could you tell me what you had done to your car [suspension wise], also were your bushings good, and did you have any prior rear collision damage.
I've searched for a while [couple of weeks], but I haven't much data on what facilitated these failures.
I do realize that the metal is thinner then the Type R's rear sub frame; also it seems that people who have run higher spring rates have not had issues. But for daily driven cars, that do auto crossing or spirited driving, I don't have much information on that.
Request:
If you have a link that has good information, could you please send it my way.
Your help is greatly appreciated.
Old Mar 31, 2006 | 11:57 AM
Voyage34's Avatar
Default Re: 96-00 Civic Rear Subframe Failure and Sway bars (lain720)
I havent experienced it myself, i have seen however, plenty of threads with different cars that have had that happen. Many of them were running softish spring rates, off the top of my head, stock springs @ 80lb/in rear, and ProKit at 190 lb/in rear.
I was running, up until about a week ago, a light rear swaybar, a gsr 14mm actually. That is fra lower than I would have to worry about any damage. I am presently waiting on my function7 endlinks to install my Blox 21mm and ASR setup.
Old Apr 19, 2006 | 07:18 AM
gabebauman's Avatar
Default Re: 96-00 Civic Rear Subframe Failure and Sway bars (Voyage34)
I've been using the 22mm ITR rear bar with the Beaks kit, Skunk2 coilovers & KYB AGX shocks. I don't consider my rear spring rate, (335lb) to be all that stiff...but I check my subframe regularly...and have NO sign of tearout. I drive the car pretty hard and have used this setup at two solo events. I'm crossing my fingers that it holds up until next month when I can finally order my ASR brace.
Old Apr 19, 2006 | 07:31 AM
heel_touge's Avatar
Default Re: 96-00 Civic Rear Subframe Failure and Sway bars (gabebauman)
ooooh ASR very nice.
i have experienced sub frame damage.
-2000 civic coupe.
-skunk2-23mm antiroll bar
-tein super street dampers
-bushings perfect
-no damage to the car
-car was never tracked only daily driven, spirited driving.
what kind of info do you need? i don't have links but i have info.
at the time i didnt even know it was possible. i went in to change out the teins for some zeals and found the skunk bar was pretty much just hanging there with only one side connected. i jumped on here and did some research and found that a larger bar with lighter rear rates with no support will often cause the rip. i think what really killed it was those shitty type of curbs that are found in newer subdivisions that are huge designed for water runoff purposes. i would be three wheeling everytime i went up one. which means i was transferring TWICE the amount of rear weight on that subframe/suspension. it was only a matter of time before it failed. long story short, I never put a bar back on and never fixed it. just seemed like so much hassle.
honestly for complete peace of mind i would strongly advise going with the A-Spec Racing subrframe brace that Gabe is talking about. they arent cheap unless you already have a bar for it. 180 forjust the brace. i planned on fixing my subframe and buying one but i wrecked the car and now my new whip has built in support from the factory
Modified by 1slowcivic at 4:44 PM 4/19/2006
Modified by 1slowcivic at 4:45 PM 4/19/2006
Old Apr 19, 2006 | 08:34 PM
R-Lug's Avatar
Default Re: 96-00 Civic Rear Subframe Failure and Sway bars (1slowcivic)
ASR!!!!! No worries, peace of mind, go carve the **** outta roads. Tried, trusted, and true
Modified by R-Lug at 11:45 PM 4/19/2006
Old Apr 19, 2006 | 08:42 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1slowcivic &raquo;</TD></TR><TR><TD CLASS="quote"> i would be three wheeling everytime i went up one. which means i was transferring TWICE the amount of rear weight on that subframe/suspension.</TD></TR></TABLE>
You were running an extreme bar with very low springrates.
My car three wheeled when on stock and Pro-Kit suspension at autocrosses without a bar. You stick a bar on there, and all that weight transfer is concentrated on the paper thin subframe.
Old Apr 20, 2006 | 05:43 AM
heel_touge's Avatar
Default Re: 96-00 Civic Rear Subframe Failure and Sway bars (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
My car three wheeled when on stock and Pro-Kit suspension at autocrosses without a bar. You stick a bar on there, and all that weight transfer is concentrated on the paper thin subframe.</TD></TR></TABLE>
yes i made that point for the thread starter so he understands why my subframe failure occured. like i said before i had no understanding of how it all worked at the time, i just threw it on there.
Old Apr 20, 2006 | 08:48 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Anyone ever experienced this with a EG/EJ? Even with a beaks kit...?
Old Apr 20, 2006 | 12:32 PM
nonsense's Avatar
Default Re: 96-00 Civic Rear Subframe Failure and Sway bars (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Anyone ever experienced this with a EG/EJ? Even with a beaks kit...?</TD></TR></TABLE>
EGs (and DCs) have a different design that doesn't seem to have the same problem as the EKs. There are lots of people running beaks on EGs with no problems at all.
Old Apr 21, 2006 | 10:19 AM
yellowturbo's Avatar
I run a Progress 24mm adj. sway bar with my Tein SS and I never had any problem. I installed the bar like they said in the instructions and I also welded the brakets to the subframe to add some reinforcement.
The rear springs are 337lbs if I remember and its on my EJ1.
Old Apr 21, 2006 | 10:45 AM
Voyage34's Avatar
Default Re: (yellowturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">I run a Progress 24mm adj. sway bar ... its on my EJ1.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">EGs (and DCs) have a different design that doesn't seem to have the same problem as the EKs.</TD></TR></TABLE>
The Progress bar uses a different mounting location IIRC that incorporates the LCA bolt and doesnt have nearly the same problem with tearout as using the stock mounting location, even on EK
Old Apr 21, 2006 | 10:09 PM
sirg-vtec's Avatar
https://honda-tech.com/zerothread?id=1543919&page=2
If you read that thread, the force of the sway bar is pulling down on the subframe. I have constructed two hypothesis.
1) The bolt from the sway bar bracket (with a kit or not) will tear a hole in the subframe.
or
2) The subframe will tear completely from the car due to the force pulling straight downward.
Its all in the thread mention above with nice pictures.
Old Apr 23, 2006 | 12:27 AM
marshun's Avatar
Default Re: (sirg-vtec)
i remember reading about this a while back. i just went with the comptech and i've never had a problem. i drive the car daily too and had the comptech piece for a couple years
nandayo
Apr 11, 2011 06:20 PM
EFRue57
Oct 15, 2009 05:15 PM
big-cat
May 20, 2007 10:58 PM
lain720
Apr 1, 2006 03:38 AM
5thgencivic
Northwest (Sales)
Oct 1, 2005 03:44 PM
