Spring rates
I'll start with my current setup: 99 Civic Hatch
CG coilovers 350F 300R on AGX adjustables. Front Si 26mm swaybar and Rear ITR 22mm swaybar with Beaks kit
It handles pretty well like it is currently, but I have a pair of rear springs with a 400 spring rate sitting in my garage that I haven't used yet. If I were to install these, what kind of handling changes would I expect?
Any advantages to running higher rates in the rear?
I don't autoX, but I do like to hit the windy roads with some spirited driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D50boy »</TD></TR><TR><TD CLASS="quote">I'll start with my current setup: 99 Civic Hatch
I don't autoX, but I do like to hit the windy roads with some spirited driving. </TD></TR></TABLE>
It's going to be a stiffer ride and will have more oversteer than it does now. I'm running Koni/GC with 450F/400R, 22mm rear sway, no front sway on my 99 Coupe.
You could also throw the 350 on the back and 400 on the front if you want.
deviant1
13
May 18, 2004 07:34 PM
snowboarderguy44
38
Nov 20, 2003 02:41 PM
AssPenny
Oct 30, 2003 01:22 PM
