FS used GSR Pistons, rods, oil pump, timing belt, clutch etc Name your price
Old Mar 31, 2006 | 08:47 AM
DJ Gurgla GSR's Avatar
Default FS used GSR Pistons, rods, oil pump, timing belt, clutch etc Name your price
All of the following items were taken from my fully stock 2001 b18c1 (gsr). All of the items have been used for 53k miles.
Just before 53k miles, I sucked water thru my CAI. This led to my rebuild. These parts were saved however.
These parts are ideal for an Ls/Vtec build on a budget! There are NO set prices. Everything is best offer. So NAME YOUR PRICE!!!
GSR Pistons / Rods<U></U> <U>Stamped P72</U>
I bent ONE rod when water was sucked in the engine. The car was driven for several miles after the 'accident'. A compression checked yielded the same results as before the accident in 3 out of 4 cylinders. Point is, 3 rods are still good. One is obviously bent, and would need to be replaced.
Each piston has a minor amount of carbon on the dome. I'm sure they can be cleaned to be nearly spotless (seafoam soak?). There is a minor surface scratch on ONE side of ONE piston. I could not get a good pic. It is MINOR, and can NOT be felt by running your finger across it. Scratch is most likely from some mishandling after being taken out of the block.
GSR Oil Pump<U></U>
Used for 53k. Plenty of life left. Only replaced cuz my rebuild was in prep for boost, and i was replacing everything basically.
It is missing one small plug fitting and a spring that goes into the pump. I don't know why I took this out but i lost it. It can be seen in the last pic. Empty hole to the right of where the oil pickup bolts too. I'm sure this plug / part can easily be found on another integra oil pump.
GSR Timing Belt / Cam Gears<U></U>
No signs of damage or wear. Used for 53k. I'm sure its good for quite awhile still (honda recommends a T belt at 90k).
Feel free to pm any questions or make any offers. All offers made will be considered unless its absolutely ridiculous.
I've sold to people here, on team-integra.net, and my ebay id is djgurgla if you are concerned about checking feedback. I try to be an honest seller, and all items are described as best I can.
With all that said.... Let the lowballing begin!
Modified by DJ Gurgla GSR at 3:45 PM 4/6/2006
Old Mar 31, 2006 | 12:56 PM
Default Re: FS used GSR Pistons, rods, oil pump, timing belt, clutch etc Name your price (DJ Gurgla GSR)
pm's replied
Old Apr 3, 2006 | 05:39 AM
ttt
Old Apr 4, 2006 | 09:00 AM
bump
Old Apr 5, 2006 | 05:42 AM
up
Old Apr 6, 2006 | 11:46 AM
updated
water pump and clutch sold
Old Apr 6, 2006 | 07:30 PM
bump
Old Apr 8, 2006 | 07:42 PM
ttt
Old Apr 13, 2006 | 12:57 PM
again
Old Apr 17, 2006 | 06:26 PM
bump
Old Apr 20, 2006 | 06:24 AM
pics are working again
Old Apr 22, 2006 | 12:00 PM
ttt
Old Apr 28, 2006 | 08:21 PM
bump
Old May 19, 2006 | 08:09 AM
SkoundrelUSA's Avatar
cute little bastard
subscribed
Old May 19, 2006 | 08:30 AM
Default Re: FS used GSR Pistons, rods, oil pump, timing belt, clutch etc Name your price (SkoundrelUSA)
still available. make me an offer if you're interested...
DJ Gurgla GSR
Jun 18, 2006 05:52 PM
iguano
Dec 12, 2005 07:02 PM
buckfittyone
Apr 22, 2003 07:32 AM
