engine is burning out white smoke?
Old Mar 31, 2006 | 06:32 AM
powwie's Avatar
Default engine is burning out white smoke?
i just build up a motor and its burning out white smoke alot of white smoke out anyone have any clue what might be the cause?
Old Mar 31, 2006 | 07:25 AM
B18C_EJ8's Avatar
Could be burning coolant.
Old Mar 31, 2006 | 11:49 AM
Lil. Cease's Avatar
white smoke means its running too rich.
Old Apr 4, 2006 | 04:15 PM
civicgeek133's Avatar
Default Re: (h23_92_lude)
no black smoke means running to rich white is coolant
Old Apr 4, 2006 | 04:54 PM
Smash03's Avatar
Default Re: engine is burning out white smoke? (powwie)
You got a coolant leak son.
Old Apr 19, 2006 | 12:50 PM
thrty8street's Avatar
Default Re: engine is burning out white smoke? (Smash03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smash03 &raquo;</TD></TR><TR><TD CLASS="quote">You got a coolant leak son.</TD></TR></TABLE>
how do you fix it?
Old Apr 19, 2006 | 03:31 PM
sc4dr's Avatar
Default Re: engine is burning out white smoke? (thrty8street)
replace headgasket possibly
Old Apr 19, 2006 | 04:36 PM
Smash03's Avatar
Default Re: engine is burning out white smoke? (sc4dr)
^^Yea, it's most likely the headgasket.
Old Apr 19, 2006 | 04:57 PM
chucky.s's Avatar
hi guys this is my first post so forgive me if i'm way off.
i had this problem on my car a few years ago and did my headgasket and still had white smoke pouring out of it.According to my mechanic it turned out that i had really badly worn valve seal which was basically letting oil pour through onto my hot piston.He then proceeded to show me by putting a few drops of oil onto my hot exhaust which surprisingly emitted white smoke.
Old Apr 19, 2006 | 05:22 PM
homiegdogfool's Avatar
Default Re: engine is burning out white smoke? (chucky.s)
whats the vehichle and its definetly not to rich if its white smoke
Old Apr 19, 2006 | 07:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">replace headgasket possibly</TD></TR></TABLE>
what if you just replaced the headgasket???
Old Apr 19, 2006 | 07:22 PM
Smash03's Avatar
Hmmm...that's weird. I've never seen oil burning into white smoke, it should be blue if it's burning oil.
Old Apr 19, 2006 | 07:24 PM
red91sit's Avatar
Not to be a dick weed, but did you replace it yourself? Could be done wrong, Hopefully it's that, other wise cracks in the block could allow coolant to pass through, hopefully not though.
Old Apr 19, 2006 | 09:07 PM
slipknottt's Avatar
Default Re: (B18C_EJ8)
What initially was wrong with the motor?
If it overheated,it could be still a few problems.
Intake could be leaking,cracked head,or block.
Someone could be pulling a fast one on you too"if you know,A good practical Joker"
A few feet of vaccuum hose,and a bottle of ATF would have someone puzzled,But Probobaly Not your problem!
Start with the simple things first,make sure of no cut corners
Old Apr 19, 2006 | 09:11 PM
slipknottt's Avatar
Default Re: (slipknottt)
By the way!
Blue smoke=oil
WHITE SMOKE=coolant
Black Smoke=fuel
Old Apr 20, 2006 | 02:33 PM
chucky.s's Avatar
i now stand corrected. (what a dissapointing first post. )
Old Apr 20, 2006 | 04:38 PM
sc4dr's Avatar
Default Re: (chucky.s)
well..... the white smoke from coolant, and the blue smoke from oil are very close in color. However, the smoke from too much fuel is very distinct. So your first post wasn't off base
Old Apr 20, 2006 | 08:58 PM
boostatic's Avatar
Default Re: (sc4dr)
u definitely have coolant gettin into atleast one of your cylinders...could be head gasket, a cylinder could be cracked, the head could be warped or cracked. you could try a cylinder leak down test to see if you're loosing pressure through 1 or more of the cylinders. basically you would get the kit and you pump air into the cylinders and see which one leaks down. its not supposed to leak much at all. that should atleast help you figure out which cylinder(s) it is.
Mikeedubb
Oct 14, 2011 03:57 AM
9hatch6
Aug 5, 2007 06:29 PM
ELSUICIDA
13
Apr 4, 2007 06:07 PM
CRX_Control
Nov 10, 2004 09:29 PM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
