Took off winter wheels, now alignment is off
Old Mar 31, 2006 | 06:26 AM
ericlee303's Avatar
Default Took off winter wheels, now alignment is off
Has this happened to anyone? When I had my new winters on, the car seemed to drive fine. Now that I put my summers on, the car wants to pull left.
Same thing happened to our AE86GTS, when we put the winters on it, the steering wheel suddenly went ****-eyed and pulled right.
Besides for the obvious (e.g. tire pressure), why would the car do this??
Thanks,
Eric
Old Mar 31, 2006 | 07:21 AM
Circa's Avatar
Default Re: Took off winter wheels, now alignment is off (ericlee303)
I experienced the same issue after changing mine, but it was mostly fixed by inflating my tires as you said... i still have a slight right pull though
Modified by Circa at 8:46 AM 3/31/2006
Old Mar 31, 2006 | 07:30 AM
nsxtasy's Avatar
H-T Order of Merit
It could be a number of things. Inflation is the most obvious. A tire defect could cause it. Maybe there is uneven wear on the summer tires. It's also possible that the alignment was off already, but you didn't feel it with the winter tires because you were using them in cold weather when there isn't as much grip (or in warmer weather when they don't have as much grip as the summer tires).
If the inflation is correct, and you don't notice anything on the tires, I would get an alignment and see if it's off.
Old Mar 31, 2006 | 07:40 AM
ericlee303's Avatar
Thanks, I think I'm going to get an alignment this afternoon anyways, just to see how much camber is off so I can adjust my camber kit.
Also, it's not the tire's fault, I had them Road-Forced, and they were fine.
Old Mar 31, 2006 | 10:59 PM
94rs-turbo's Avatar
rotate the tires just cross the fronts see if it pulls the other way if it does then u have a bad tire
Old Apr 1, 2006 | 10:04 AM
SlammedDC2teg's Avatar
Check the rotation of the tire. It might be on the wrong side.
Old Apr 1, 2006 | 10:14 AM
ericlee303's Avatar
Thanks guys, 94RS was correct...it was a radial tire pull problem:
http://www.tirerack.com/tires/...id=12
However, I rotated the front tires side-side and the problem strangely went away for now...
Old Apr 1, 2006 | 05:08 PM
94rs-turbo's Avatar
Default Re: (ericlee303)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ericlee303 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys, 94RS was correct...it was a radial tire pull problem:
However, I rotated the front tires side-side and the problem strangely went away for now...</TD></TR></TABLE>
thanx but..... thats odd but go with it lol go somewhere where they do alignment check for free just to see if it out first atleast here an NTb where i work we dont charge to check the alignment first
ten2doyle102
Mar 4, 2009 07:44 PM
jmccalip
Apr 24, 2008 06:38 PM
EJ1 wilcox
Suspension & Brakes
Feb 28, 2006 06:27 PM
b20integrapower
Feb 23, 2006 02:55 PM
neopheus
Suspension & Brakes
Mar 17, 2005 08:02 PM
