engine will not start under hot conditions. Main relay or ignition switch or both?
I own a 92 vx hatch. Lately under warm/hot conditions like after driving the car or lately when it is worm out side the car will either
A) crank and crank and crank over but not start or
B) crank and start for a quick second and stall and then will not start again (crank and crank and crank over)
it seams to be getting worse. yesterday it did the same thing when I got home from work (car had been sitting all day in the sun). I went out and came home in the eveninng when it was cool and tried to start the car. It started right up! So M y question is I have searched and I have come up with 2-3 posibilities.
1) main relay
2)ignition switch
3) both
I don't want to go to honda and buy both. I need some advise people.
thanks
1) main relay
2)ignition switch
3) both
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist »</TD></TR><TR><TD CLASS="quote">I vote for the main relay. Pull it, resolder it, and off you go.</TD></TR></TABLE>
i had the same problem... I always thought it was my ignition but i found out it was my relay, try checking relay
popthatclutch13
Sep 20, 2018 03:12 AM
vladiscoolej1
15
Oct 23, 2010 06:55 PM
Tad
Jan 3, 2006 06:37 PM
