Cylinder head torque sequence
Old Mar 31, 2006 | 05:16 AM
stockcivic103's Avatar
Default Cylinder head torque sequence
Like the title says, i know what to torque them at.... i just dont know the sequence, can anyone help me out?
its a 92 civic with a d15b8 with a d15b7 head on it
thanks in advance if anyone knows
Old Mar 31, 2006 | 05:29 AM
impound's Avatar
Default Re: Cylinder head torque sequence (stockcivic103)
start in the center and work your way out, criss-crossing as you go
Old Mar 31, 2006 | 10:03 AM
DRAMA's Avatar
Default Re: Cylinder head torque sequence (impound)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by impound &raquo;</TD></TR><TR><TD CLASS="quote">start in the center and work your way out, criss-crossing as you go</TD></TR></TABLE>
corect but its a 2-stage torquing sequence. meaning you need to first torque the bolts down to whatever the factory spec is (ex: 22 lbs) and then go at it again with the same sequence at whatever the factory spec is (ex: 58 lbs). invest in a service manual or look up an online manual for the exact torque specs and there will also be a picture showing you the cris-cross pattern to do.
.PLUMMM
Mar 10, 2007 07:27 PM
Rxmig7
Feb 24, 2006 08:11 AM
socaly4life
Jan 9, 2005 10:52 PM
shivic
Aug 4, 2004 10:41 PM
jdmlsvtecrx
Sep 11, 2003 09:48 AM
