Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Unscrewing the shiftnob, help
Old Mar 30, 2006 | 09:19 PM
06SImofo's Avatar
Default Unscrewing the shiftnob, help
I just tried my god damn hardest to unscrew the shift *** for my Si. Am i doing something wrong? Does it screw off or pop off.
Plz help a 06 Si brother out.
Old Mar 30, 2006 | 10:09 PM
01-1293's Avatar
Default Re: Unscrewing the shiftnob, help (06SImofo)
i thought all hondas screw off.....
Old Mar 30, 2006 | 10:31 PM
06SImofo's Avatar
Default Re: Unscrewing the shiftnob, help (01-1293)
i'll probably half to use clamps or something, that **** is on there hard.
Old Mar 30, 2006 | 11:29 PM
pvt. snowball's Avatar
i dont kno but i think the stalk shift *** looks clean or eles u got sumthing better
Old Mar 31, 2006 | 04:28 AM
Sleepy_Red_hatch's Avatar
Default Re: Unscrewing the shiftnob, help (pvt. snowball)
this is the proper way to unscrew it
1.push the boot back (away from the ****)
2.once the **** is completely exposed, screw it off...the boot has a lip tha the **** hang on to
Old Mar 31, 2006 | 04:42 AM
Type X's Avatar
did you remove the locking nut underneath the **** itself?
Old Mar 31, 2006 | 05:48 AM
TRAG's Avatar
yeah...ther is a nut or a bolt or something you have to loosen or remove twords the bottom of the shifter.
Old Mar 31, 2006 | 07:14 AM
aspec101's Avatar
Default Re: (TRAG)
this definately has to be one of the lamest posts ever....If you can't figure out how to take a shift **** of your probably better off leaving it on. Besides whats wrong with your stock one?
Old Mar 31, 2006 | 08:31 AM
06SImofo's Avatar
Default Re: (aspec101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aspec101 &raquo;</TD></TR><TR><TD CLASS="quote">this definately has to be one of the lamest posts ever....If you can't figure out how to take a shift **** of your probably better off leaving it on. Besides whats wrong with your stock one?</TD></TR></TABLE>
Your too cool for school.
Old Mar 31, 2006 | 09:14 AM
Type X's Avatar
nothing wrong with NOT knowing anything
how do you think people learn?
you weren't born knowing how to drive a car?
pay taxes
log onto a computer
YOU LEARNED IT....
Old Mar 31, 2006 | 11:33 AM
aznboi04k's Avatar
"this definately has to be one of the lamest posts ever....If you can't figure out how to take a shift **** of your probably better off leaving it on. Besides whats wrong with your stock one?"
arrogant. ignorant.
Old Mar 31, 2006 | 01:07 PM
dlux200sx's Avatar
Default Re: (aznboi04k)
So when do I loosen the bottom bolt? At the same time I unscrew the ****? before? after? Also, lets say I'm looking directly down at the ****. I turn it counterclockwise right? I assume the bolt will unscrew the opposite direction as the ****.
Old Mar 31, 2006 | 01:47 PM
06SImofo's Avatar
I wish i was born with knowlege like you were.
We all had to learn about everything at one time. If no one told me and I didnt research it, how am I suppose to know? This is what internet forums are for! If it wasnt for quesitons like mine, no one would post anythign and everyone would be bored as hell at work/home.
DIAF
Old Mar 31, 2006 | 03:59 PM
Curt941's Avatar
Default Re: (06SImofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06SImofo &raquo;</TD></TR><TR><TD CLASS="quote">
DIAF
Dude, shut the expletive up, seriously...IT'S A ******* SHIFT ****!!!! You're not welding up a custom turbo manifold or installing new pistons...jesus christ, if you are so mechanically incompetent that you can't figure out how to get a shift **** off, then you're an idiot...seriously, it's not rocket science...did you try anything besides just turning it??? Did you look under the shift boot for a lock nut, or did you just twist it a little bit and then run onto HT to find out how??? Usually i'm understanding when someone has a tech question, but this is ******* ridiculous...
Old Mar 31, 2006 | 06:22 PM
Type X's Avatar
Default Re: (dlux200sx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dlux200sx &raquo;</TD></TR><TR><TD CLASS="quote">So when do I loosen the bottom bolt? At the same time I unscrew the ****? before? after? Also, lets say I'm looking directly down at the ****. I turn it counterclockwise right? I assume the bolt will unscrew the opposite direction as the ****.</TD></TR></TABLE>
remove bolt counter clockwise
lefty looosey
and than remove the ****
Old Mar 31, 2006 | 06:26 PM
pat.ter.rick's Avatar
Default Re: (Curt941)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curt941 &raquo;</TD></TR><TR><TD CLASS="quote">Dude, shut the expletive up, seriously...IT'S A ******* SHIFT ****!!!! You're not welding up a custom turbo manifold or installing new pistons...jesus christ, if you are so mechanically incompetent that you can't figure out how to get a shift **** off, then you're an idiot...seriously, it's not rocket science...did you try anything besides just turning it??? Did you look under the shift boot for a lock nut, or did you just twist it a little bit and then run onto HT to find out how??? Usually i'm understanding when someone has a tech question, but this is ******* ridiculous...
wow shift ***** are different now..their not like your "ITR" and my dc2.. they don't just screw right off that easily.. the 06 si you gotta grab the shift boot and move it away from the shift know.. i believe you do the same with the EP3. so if you don't have anything nice to say don't post.. if you want to yell and **** just yell at the computer instead of making the OP look bad. so what if he has trouble with the shift ****.
to the OP:
forget guys like Curt941 and the other guy.. just listen to Type X. hes a good personto learn from..
Old Mar 31, 2006 | 09:57 PM
Curt941's Avatar
Default Re: (g0t vtec-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0t vtec- &raquo;</TD></TR><TR><TD CLASS="quote">
to the OP:
forget guys like Curt941 and the other guy.. just listen to Type X. hes a good personto learn from..</TD></TR></TABLE>
Fock that, how hard is it to try more than just twisting???? jesus christ
FNO1R
Nov 2, 2007 02:55 PM
06SI=superior
Mar 26, 2007 01:33 PM
jdmxtacy
Dec 26, 2005 07:48 PM
pre1udekid
Jul 12, 2004 03:49 PM
acme
Jun 16, 2003 03:15 PM
