Suspension & Brakes Theory, alignment, spring rates....
Need Help with omni power drag
Old Mar 30, 2006 | 08:57 PM
JDM_Andrew's Avatar
Default Need Help with omni power drag
i found the answer!
Modified by Drewkraft at 10:07 PM 3/30/2006
Old Mar 30, 2006 | 09:08 PM
Voyage34's Avatar
Default Re: Need Help with omni power drag (Drewkraft)
https://honda-tech.com/zerothread?id=1569922
double post much?
as before, the omni drag coilovers are 18k which is far and above what should normally be run on the street. you can call omni and ask them how to and if its even possible to soften those, if not then you can just buy a new setup thats more street and daily driver friendly
*edit* <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drewkraft &raquo;</TD></TR><TR><TD CLASS="quote">i found the answer!</TD></TR></TABLE> there you go!
Old Mar 30, 2006 | 09:13 PM
JDM_Andrew's Avatar
Default Re: Need Help with omni power drag (Voyage34)
sorry it was just bothering me and i just skimmed the other post and didnt read it too well but i just did and ill probably just buy new suspension.
Old Mar 30, 2006 | 09:14 PM
Voyage34's Avatar
no worries, its solved
Old Mar 30, 2006 | 09:15 PM
JDM_Andrew's Avatar
thanks for your help
kielcivic
Suspension & Brakes
Jun 9, 2012 12:37 AM
95dxsir2
Nov 18, 2007 12:43 PM
HatchSi
Nov 3, 2006 08:23 AM
InDub
Jan 18, 2006 05:16 PM
vtakk eg
Suspension & Brakes
Apr 30, 2005 02:13 PM
