skunk 2 intake manifold problem
I just installed a new Skunk 2 intake manifold on my b16 and its running like ****!! I used new gaskets but it sounds like there is a leak coming from the throttle body has anyone had simular problems, or ideas on what the hell is going on?
Yepper new intake and throttle body gaskets.
I'm gonna pull all the connections this weekend and make sure they r right but i think i hooked it all up right.
same here, I gotta go back through and make sure the bolts that hold the throttle body to the intake are tight. That is where I think my leak might be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-bird »</TD></TR><TR><TD CLASS="quote">Yepper new intake and throttle body gaskets.
I'm gonna pull all the connections this weekend and make sure they r right but i think i hooked it all up right.</TD></TR></TABLE>
its gonna have 2 be a gasket from skunk2 and not honda. and check your tps on the throttle body make sure its just like stock . i did mine through my vafc2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_203 »</TD></TR><TR><TD CLASS="quote">its gonna have 2 be a gasket from skunk2 and not honda. and check your tps on the throttle body make sure its just like stock . i did mine through my vafc2</TD></TR></TABLE>
I used the throttle body gasket from skunk2 and a factory intake manifold gasket.
TPS voltage should be .5 at fully closed and approximately 4.5 when fully open right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95b16hatch »</TD></TR><TR><TD CLASS="quote">I just installed a new Skunk 2 intake manifold on my b16 and its running like ****!! I used new gaskets but it sounds like there is a leak coming from the throttle body has anyone had simular problems, or ideas on what the hell is going on?</TD></TR></TABLE>
I have an 99 Si and I bought a Skunk 2 intake manifold and the only problem I had with it was after i was pretty much done I noticed I put the throttle body gasket on like upside down or something. That made it run like straight ****. took it back off and then turned it to the right way and everything was perfect.
Went through and checked all the wires and tightened all the bolts and its running alot better now. Gotta check the throttle body gasket and hopefully it is running right after that.
sloweh3
12
Oct 22, 2007 09:29 AM
Duck Sauce
Nov 28, 2001 08:47 AM
