what gauge is factory transmission ground wire?
Old Mar 30, 2006 | 08:13 PM
potatostix's Avatar
Default what gauge is factory transmission ground wire?
I have 4 gauge wire, but after removing the factory ground wire I'm not sure they're the same size. The factory one is slightly larger(caliper showed almost 8mm, while the 4 gauge wire is 6). The factory one is just a bunch of fairly large strands, but the 4 gauge I got has alot of fine strands and is wound in a spiral. Should I use this or find a larger gauge wire? I'm not sure if its going to be as good since its smaller, but it is a better made oxygen free wire. Thanks.
Old Mar 30, 2006 | 10:02 PM
s_vares's Avatar
Default Re: what gauge is factory transmission ground wire? (potatostix)
Its a 4 guage, maybe more sheilding.
But yeah they are 4
EG-SIXV-TEC
Oct 19, 2009 01:45 PM
Voodooboy520
Dec 3, 2005 03:59 PM
C-Zero
May 9, 2004 05:33 AM
mrlegoman
Feb 3, 2003 04:15 PM
