How To: Civic Hatch/CRX power lock install.
Old Mar 30, 2006 | 07:04 PM
xci_ed6's Avatar
Default How To: Civic Hatch/CRX power lock install.
Here are 3 latches, hatch/CRX, 4d front, 4d rear. Notice the fronts are very similar, and the lock actuators on the 4d ones are also very similar.
Close up of the hatch/crx latch. Notice it has the peg that the actuator engages, as well as tapped holes for the actuator to bolt to.
Detail of the 4D front latch. Notice it is actually the same except it is missing the part the turns the interior manual lock 90*, this is because the 4D has the locks by the window, not the handle. The bracket for this piece is still here. It also has one extra wire comming out of the sensor body, i don't know what it is for.
Detail of 4d rear actuator. Notice it is even stamped with the same part number as the front actuator. The only difference is it has only 2 wires for lock/unlock. I believe the other 2 wires on the front actuatorare for some type of sensor.
So with only 3 screws, I took the actuator off the rear latche (simpler, only 2 wires) and screwed it onto the hatch/crx latch.
After much hassel i realized that it must be assembled inside the door unless I want to remove the window tracks. I also found that the support for the door mounted seatbelt retractors interferes with fitment. Tomorrow I will cut that **** out and have a picture of how it fits
Wiring should be similar to the power window project found here:
https://honda-tech.com/zerothread?id=1575257
Old Mar 30, 2006 | 07:12 PM
kcjohnnyboy's Avatar
good stuff...i already got the power windows also...only if i knew about using the 4dr door lock actuators...but my aftermarket ones work as good
Old Mar 30, 2006 | 07:57 PM
1989CivicSi's Avatar
Default Re: (kcjohnnyboy)
Thanks, excellent write up . By any chance would that extra wire for the sensor be for the door ajar light? Just wondering .
Old Mar 30, 2006 | 08:16 PM
xci_ed6's Avatar
Default Re: (1989CivicSi)
hatches and CRX's have the light too, if i feel like lookin through the FSM later I'll be sure to post what it is for.
Old Mar 30, 2006 | 09:42 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (krustindumm)
the extra wire is a switch so when u push down on the lock on top of the door it will lock all doors. this switch is also the one that lock all doors when u lock the door w/ the key
EDIT. i found a schematic for u
Old Apr 2, 2006 | 07:08 PM
citycivic415's Avatar
THANK you you guys have just made my day
Old Apr 4, 2006 | 01:12 PM
xci_ed6's Avatar
Default Re: (citycivic415)
so no update for awhile...blew up the clutch in my 240 and been busy with that. Maybe later this week though.
Old Apr 4, 2006 | 01:17 PM
cbp_crx's Avatar
thanks for the info, been wanting to do this, also good to see another person reppin iowa in here
Old Apr 4, 2006 | 03:07 PM
xci_ed6's Avatar
Default Re: (cbp_crx)
could be longer than that now. keep hitting roadblocks.
First my jack died mid swap, now the tranny slipped off the new jack and hit me in the head. I think it destroyed the new clutch too.
Old Apr 10, 2006 | 09:23 AM
YumVTEC's Avatar
keep us posted.
Old Jul 29, 2006 | 04:16 PM
jmart62's Avatar
Default Re: How To: Civic Hatch/CRX power lock install. (krustindumm)
krustindumm
I wanted to ask you a couple of questions about this swap. Are your hatch/crx door latches actually out of a crx or a hatchback? Also what year is the car they came from?
I have been doing power upgrades on my car and my 91 crx latches are not the same as the ones you show on your writup. I look forward to your response.
Old Jul 29, 2006 | 07:08 PM
platinumx6's Avatar
is this for a manual lock/manual window to power upgrade? How much do these parts cost and are the aftermarket or are they out of junkyards? Is it different for a first gen crx? (87)
Old Jul 29, 2006 | 11:38 PM
La EF-8's Avatar
good write up.. keep us updates
EusebioSam19
Apr 2, 2010 10:10 AM
crxsi_guy
Feb 16, 2006 05:24 PM
md88hfcrx
Jan 1, 2006 07:24 PM
CRXNuts
Nov 1, 2004 07:31 PM
