tranny fluid question
i have a 91 sedan with a 5 speed tranny and my question is how can I put tranny fluid in it and what kind ? any imput will be greatly appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">HELMS MANUAL. Everyone needs one!
And as for only using Honda MTF. That's BS. I use Penzoil Synchromesh and it does wonders.</TD></TR></TABLE>
yea my friend said the same thing about using regular oil, where can i get a helms manual
the fill plug is just above and to the rear of where your passenger side axle shaft enters the tranny. its just a 17mm plug, gonna need a wrench, its a tight squeze. you can use 10w40 oil, honda mtf, gm syncromesh, or the penzoil varient. fill it up until the fluid pours back out the hole at you then just put the plug in it. i'd say if your going through the trouble of adding fluid you might as well just drain it first and pull all new fluid in it.
Kaliona
38
Aug 3, 2009 05:53 PM
