D series pistons in ZC??
Old Mar 30, 2006 | 02:14 PM
JDM_ZC's Avatar
Default D series pistons in ZC??
its hard to find parts for my aftermarket parts for my ZC...will D series Pistons fit into my ZC??
Old Mar 30, 2006 | 02:26 PM
migizzel's Avatar
Default Re: D series pistons in ZC?? (JDM_ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_ZC &raquo;</TD></TR><TR><TD CLASS="quote">its hard to find parts for my aftermarket parts for my ZC...will D series Pistons fit into my ZC??</TD></TR></TABLE>
could you be a bit more clear in your question?
Old Mar 30, 2006 | 03:39 PM
Steve91's Avatar
Are you talking about putting SOHC d16a6 pistons into a DOHC d16a1? Is so, they will fit, but your compression will be low and they might need to be milled a tiny bit because they are a little taller.
Old Mar 30, 2006 | 04:17 PM
JDM_ZC's Avatar
Default Re: D series pistons in ZC?? (Steve91)
yes I am talking about puttin any D series performance pistons into a DOHC ZC...unless anyone knows where I can find parts specifically for the ZC...
Old Mar 30, 2006 | 04:20 PM
Go n 4 10s's Avatar
yes they will fit but ZC pistons are nice Why change it????
Old Mar 30, 2006 | 04:34 PM
theemaddhatterr's Avatar
If you are looking for aftermarket pistons than check out theoldone.com
Old Mar 30, 2006 | 04:40 PM
DEIVIONCRX's Avatar
Default Re: (Go n 4 10s)
any Dseries pistons will fit in any dseries, the DOHC ZC has the biggest dome i know about so your gona loose compression unless you find some nice dome Aftermarkets, or if your wanting to boost find some low compression wiesco's or whatever
all dseries are 75mm bore
Old Mar 30, 2006 | 05:59 PM
Tippyman's Avatar
lol, look on the front page, there's another thread about this. Isn't this in the FAQ?
[sarcasm] hmmmmm....? [/sarcasm]
Old Apr 2, 2006 | 10:12 AM
JDM_ZC's Avatar
Default Re: (Tippyman)
if its in the FAQ i'm sry I didn't read there lol....the ZC pistons are good but I cant find any aftermarket ones so I was gonna find some aftermarket D-series pistons to put in my ZC....thanks for the help tho
Old Apr 2, 2006 | 10:15 AM
hatchinprogress's Avatar
Default Re: (JDM_ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_ZC &raquo;</TD></TR><TR><TD CLASS="quote">if its in the FAQ i'm sry I didn't read there lol....the ZC pistons are good but I cant find any aftermarket ones so I was gonna find some aftermarket D-series pistons to put in my ZC....thanks for the help tho </TD></TR></TABLE> yes if your lookin for after market pistons use d-series pistons they will fit (as long as there the same bore as your cylinders). look around for the compression calculator (i think it's in the faqs) and enter the info to see which pistons will work for you/your set-up
Bserieskiller
Jan 8, 2020 07:24 PM
tommy.
Jun 20, 2009 04:28 AM
solerizr
Jan 3, 2007 04:41 PM
Turbo Neon
Feb 3, 2004 09:18 AM
