Signs of a bad ignition?
Old Mar 30, 2006 | 02:06 PM
pinecone's Avatar
Default Signs of a bad ignition?
Well I went to start the car and it won't start. Whe I turn the car nothing comes on, none of the accessories or the dash. Would this indicate a bad ignition?
Could the cylinder be bad? Would that require me to get a new key?
I just thought about the fuses. I am gonna check that when I get off work tomorrow.
Modified by pinecone at 5:08 PM 3/30/2006
Old Mar 30, 2006 | 05:50 PM
ck123's Avatar
bad ignition is when the crank sounds horrible or really slow
Old Mar 30, 2006 | 06:43 PM
mahatma's Avatar
Default Re: (ck123)
Check the battery ground connection.
Old Mar 30, 2006 | 07:28 PM
Mugencrxsir1's Avatar
Default Re: (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">Check the battery ground connection.</TD></TR></TABLE>
Also, charge your battery.
Old Mar 31, 2006 | 01:43 AM
pinecone's Avatar
Default Re: (Mugencrxsir1)
Alright, I will check those after I check the fuse.
Old Mar 31, 2006 | 01:13 PM
pinecone's Avatar
Default Re: (pinecone)
Hmm, looks like I blew the 50amp ignition relay. I really need to get the ignition wire fixed.
memo9259
Apr 7, 2014 10:50 PM
southernSCHEME
Dec 26, 2009 04:23 PM
ParistsCP
Oct 22, 2008 07:24 PM
strils
Jan 11, 2007 08:06 PM
veeDUB
Mar 22, 2004 09:37 AM
