Removing plug from connector (atts ecu / main ecu)
Old Mar 30, 2006 | 12:49 PM
vinuneuro's Avatar
Default Removing plug from connector (atts ecu / main ecu)
How do you get the damn plugs out of the atts ecu and the main ecu? There's basically nothing to grip onto and they're in there pretty solid even when you push the tabs down on the connectors. Tried sticking a screw driver on the tab to keep it down, no where to grip to pull it out.
Modified by vinuneuro at 4:05 PM 3/30/2006
Old Mar 30, 2006 | 01:34 PM
vinuneuro's Avatar
Default Re: Removing plug from connector (vinuneuro)
bump for desperation.
Old Mar 30, 2006 | 01:36 PM
Shakes's Avatar
space cadet
if you lifted the metal plate upward, the tab is underneath. press in and pull firmly straight out. They take some oomph.
Old Mar 30, 2006 | 01:43 PM
vinuneuro's Avatar
Default Re: Removing plug from connector (Shakes)
That's what I did. I guess I need to pull harder? Did you just push the tab down with your finger and pull?
Old Mar 30, 2006 | 02:02 PM
Shakes's Avatar
space cadet
push the tab into the plug
Old Mar 31, 2006 | 05:06 AM
vinuneuro's Avatar
Pulling the clock/radio fuse or disconnecting the battery should clear the atts codes right? I've tried a different ecu, and with mine and this one, the light is always on when i turn on the ignition. Why won't they clear?
Old Mar 31, 2006 | 07:47 AM
Chuckles99SH's Avatar
It should clear the ECU by pulling your clock fuse. However if there is something wrong with your ATTS it might be something that a ECU reset wont clear.
Old Mar 31, 2006 | 07:53 AM
Shakes's Avatar
space cadet
Default Re: Removing plug from connector (Chuckles99SH)
When you pull the codes what flashes? Is it JUST the ATTS light flashing?
Old Mar 31, 2006 | 04:16 PM
vinuneuro's Avatar
Just the ATTS light is on. The code i got with the OE ecu was 42,43: pgmfi communication line .
With the other ecu I am getting 42 and 51 (Faile-safe relay). I haven't even begun troubleshooting. Well, the first step in trouble shooting is clear code and test drive, but the codes won't clear.
I tried the specific procedure for clearing the atts code in the helms and that didn't work. I went to dealer, and they tried clearing the code with the pgm tester and it wouldn't clear. So I borrowed this atts ecu, same deal.
Few weeks back, I got code 42, and I just pulled the clock/radio fuse and it went away.
Old Apr 1, 2006 | 04:25 PM
Shakes's Avatar
space cadet
if just your atts light is flashing then you have an actual ATTS issue. You would have to read the ATTS light to get that code and reference it to your helm manual.
93baggedcivic
Jun 23, 2007 10:43 AM
Rukusmasta2
Feb 17, 2003 03:01 PM
joblow
Feb 12, 2003 07:17 PM
Toda Party
Oct 9, 2001 10:56 PM
