BKR7E-11?
Old Mar 30, 2006 | 10:06 AM
OMG WTF's Avatar
Default BKR7E-11?
I'll be doing a tune up for another project car i just got. Would the BKR7E-11 be a good match for the stock ITR motor? Or do you have something else you would recommend?
Old Mar 30, 2006 | 10:16 AM
D-Rob's Avatar
Default Re: BKR7E-11? (zclee.com)
I am almost positive the stock ITR plug is a BRK6E.
A 7 heat range plug will make your car feel like *****.
...That is, unless you're turbo, or have 11.7:1 compression, like me.
Old Mar 30, 2006 | 11:49 AM
( o )( o )'s Avatar
Default Re: BKR7E-11? (D-Rob)
can we start some informative dialogue on this topic? i have search & asked before but have yet to find solid info.
from what i just read on denso's website, the lower the number the hotter the plug.
I recall hearing people with turbo setups needing a cooler plug. with that logic then, do the n/a motors prefer hotter plugs?
****. i was running the bkr7e-11's in my b16 with ctr pistons....perhaps I should get the BRK6E's?
Old Mar 30, 2006 | 12:00 PM
akura404's Avatar
Default Re: BKR7E-11? (( o )( o ))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o ) &raquo;</TD></TR><TR><TD CLASS="quote">can we start some informative dialogue on this topic? i have search & asked before but have yet to find solid info.
****. i was running the bkr7e-11's in my b16 with ctr pistons....perhaps I should get the BRK6E's?</TD></TR></TABLE>
Exactly what I was thinking!
Old Mar 30, 2006 | 12:03 PM
D-Rob's Avatar
You were fine with the BRK7E's, but you could have gotten away with the 6's.
High compression N/A engines produce similar cylinder pressures and heat as boosted cars. Thus, you need a cooler plug to help dissapate that heat.
I ran some 6 heat range plugs on my engine for a good while, and could never get a good reading out of them to tell if I was detonating or not.
Then, my tuner suggested a cooler plug, such as the BRK7E plug that he uses on his turbo cars. Since my compression read 285psi, he suggested the cold plug.
Now, I can read my plugs perfectly, and they're not melting themselves down.
- Derek
Old Mar 31, 2006 | 08:00 AM
EJtypeR's Avatar
ive been running bkr7e-11 for 2 years now...with a ITR no problems
Old Mar 31, 2006 | 09:45 AM
Black R's Avatar
25 Year Member
look up ngk's website and their application guide says bkr7e-11's are for itr's.
Old Mar 31, 2006 | 11:13 AM
D-Rob's Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">look up ngk's website and their application guide says bkr7e-11's are for itr's.
I stand corrected.
high_revs
Oct 30, 2005 01:01 PM
hondaguyef
Apr 13, 2005 01:01 PM
type r 01-1063
Apr 19, 2004 02:29 PM
Shft@9GSR
Oct 16, 2003 12:04 PM
Chubz
Jul 23, 2002 04:52 AM
