Piston Slap, Rod Knock, Water Pump?
Old Mar 30, 2006 | 09:29 AM
warwagon's Avatar
Default Piston Slap, Rod Knock, Water Pump?
Well just had my c5 rebuilt new rings and bearings and a slight hone. My guy came down and scoped it and when you put the scope to the water pump and the motor is cold and you barely modulate the throttle, when it revs back down you can hear a tick for a few seconds.... once the motor warmed up it won't do it at all... i've searched and i am going to pull the filter and cut it open to see if there is any copper.
I've been beating on it a little bit and the noise hasn't gotten any worse?
sorry for the shitty grammar ... my nerves are about shot over this ****!
Old Mar 31, 2006 | 06:57 AM
warwagon's Avatar
Default Re: Piston Slap, Rod Knock, Water Pump? (warwagon)
one more
Old Mar 31, 2006 | 07:39 AM
SkRiBLaH's Avatar
what if when you pull the drain plug and see silver shavings? whats the deal with copper shavings?
Old Mar 31, 2006 | 10:39 AM
warwagon's Avatar
Default Re: Piston Slap, Rod Knock, Water Pump? (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">what if when you pull the drain plug and see silver shavings? whats the deal with copper shavings?</TD></TR></TABLE>
all bearing shavings i have see have been copper? iirc
flood
11
Apr 16, 2020 12:11 PM
BigMoose
Aug 28, 2005 03:46 PM
MyVtec8yourV8
Jan 6, 2005 04:12 PM
b16acrxer
Apr 14, 2004 08:08 AM
Frankie324
Jan 29, 2003 07:07 AM
