Azenis tire pressure?
I've had them on for almost 2 weeks now and they are great handling, but the car feels sluggish, almost like if the tires were low but the pressure is actually higher than spec. I have 205/55/15.
Is it because the rubber is that soft?
What tire pressure are you guys running?
anyway, I'm using Azenis (205/50/15), I put 35/33 psi (same as stock) when driving on street.
As for AutoX......I raised the pressure to 39/39 psi to get more rotation.
Yeah, they do feel a little softer...
for track I run ~35-36 front, ~39 rear. (cold)
you should run lower in front for track cause you have to take into consideration the increase pressure from heat generated from hard brake use.
I've tried different pressures on my Azenis at the last event and ended up running 43f 48r. This is on a Talon, so it might like different pressures from an itr. However, when I used to autox an itr about three years ago on A032Rs, I was running very similar pressures. If the tires feel sluggish, just try raising the pressure.
I am most likely gonna run Solo2 this weekend, what air pump do you guys recommend. The 5lb tank or the car ligther pump?
https://honda-tech.com/zerothread?id=157368
-jeff who runs 36/34 on street and 39/38 or 40/39 on track on his azenis
Understeer
Jul 20, 2005 07:37 PM
