d15b parts
Old Mar 30, 2006 | 08:06 AM
BoostFrenzy.com's Avatar
Default d15b parts
If I was going to replace the cap/rotor, timing belt, water pump and tension pulley, etc. for a JDM d15b.. can I use any D-series parts for that?
Sorry if it's a n00bish question. Thanks for the answer tho
Old Mar 30, 2006 | 08:15 AM
Scarface928's Avatar
From: Northern Virginia home of missing hondas, USA
Default Re: d15b parts (Mafiozo)
Most parts will work but some are alittle different.
Old Mar 30, 2006 | 08:27 AM
Default Re: d15b parts (Scarface928)
I havent had much luck finding out part numbers or anything like that. Looking to find out specifically what part numbers or subsitutions I can make.
Old Mar 30, 2006 | 09:15 AM
schardbody's Avatar
easy question, anything for the BLOCK ie: waterpump, timing belt tensioner etc. are interchangeable with a USDM d15z1. anything head wise is interchangeable w/ D16z6. oh and any dizzy parts ie: cap, rotor, wires, etc. are the same as any USDM obd1 vtec motor.
Old Mar 30, 2006 | 09:28 AM
D16SohcVtec's Avatar
Is this the d15b with or without vtec? I use to have a nonvtec d15b I just used the d15b7 parts and worked fine for me.
Old Mar 30, 2006 | 09:59 AM
theharlequin's Avatar
http://www.d-series.org/forums...32597
have fun
Old Mar 30, 2006 | 10:14 AM
schardbody's Avatar
yes i was talking about the obd1 JDM D15b vtec.
hermistonkilla
17
Jan 10, 2009 08:47 AM
headrec*
Apr 25, 2007 03:07 AM
jpciii
27
Sep 29, 2006 05:55 AM
toonces
Apr 26, 2004 10:20 AM
NatedoggAZ
Jul 26, 2003 11:36 AM
