Main bearing clearence? ACL too tight
Old Mar 30, 2006 | 06:29 AM
DanishR's Avatar
Default Main bearing clearence? ACL too tight
The ACL bearings comes out a little tighter than 1 thousand of an inch on all the mains on my motor. Which bearings to get?
Looking at this: https://honda-tech.com/zerothread?id=715490 it seems to me that if I chose "pink" bearings instead, I would get around 0.6 thousands more clearence than the ACLs (If the ACLs really are the same as OEM greens). Just wanted to know if that is correct before ordering new bearings. Thanks.
Old Mar 30, 2006 | 03:15 PM
DanishR's Avatar
Default Re: Main bearing clearence? ACL too tight (DanishR)
up
Old Mar 31, 2006 | 01:00 PM
DanishR's Avatar
Someone with engine building experience must know this.
Old Apr 1, 2006 | 05:22 AM
NAlover's Avatar
Hey, so you know, you can cut your price on those acl bearings in half.
http://www.autohausaz.com
parts:
acu061522
hon061503
hon048639
$55.90 shipped.
What do you think about this??? i'm building my lsvtec and i really want to get the right bearings. and someguy in H.T gave me that info...
Old Apr 1, 2006 | 06:38 AM
DanishR's Avatar
Default Re: Main bearing clearence? ACL too tight (NAlover)
Thanks for the link.
If your motor needs green bearings the ACLs will be fine I have read.
This is a good read: http://forums.evans-tuning.com...light
You can also see which clearences are acceptable in that link.
Back to my question...
Old Apr 1, 2006 | 06:56 AM
postman's Avatar
did you precrush them before mesuring clearance
Old Apr 1, 2006 | 01:59 PM
DanishR's Avatar
Default Re: Main bearing clearence? ACL too tight (postman)
Precrush? I never heard of that before. What do you mean by that?
Old Apr 1, 2006 | 05:00 PM
postman's Avatar
before installing crank and mains. you torque the mains down with the bearings first to seat themin th cups
Old Apr 1, 2006 | 06:24 PM
d16dcoe45's Avatar
If you are getting a bit tighter than 0.0010 say 0.0008-0.0009"--try the HX race bearings--they are 0.001" looser so your clearances will be around 0.0018"-0.0019"--which is good. the ACL Hx
Old Apr 10, 2006 | 04:36 AM
DanishR's Avatar
Default Re: Main bearing clearence? ACL too tight (d16dcoe45)
I guess I'll try out the ACL race then. Same clearences after "precrushing".
Old Apr 12, 2006 | 05:29 PM
NAlover's Avatar
i'm building a lsvtec since i'm using high CR pistons and eagle rods the mechanic told me to buy ACL bearings... Now my question is ACL got stokl and 0.25mm (.010") O/S sizes which one should be better???
MadVTI
Oct 4, 2009 05:47 PM
marcussmith26
Jan 17, 2006 02:45 PM
60-1
Feb 15, 2004 09:08 PM
