OBD1 conversion vtec wiring help
Old Mar 30, 2006 | 05:57 AM
Concept Tuning's Avatar
Default OBD1 conversion vtec wiring help
Ok the instuctions with the OBD1 conversion are kinda vague. They just tell the name of the plug and what wire to use. I don't know the name of the plugs so I don't know what goes where.
There is a black plug that comes off the vtec solenoid, what goes there/what is this called? There is only one connector inside.
Then there is the green plug that I assume is the oil pressure. There are two connectors inside.
Now there are only 2 wires that say they go to vtec, so whats the deal with the three connections.
Old Mar 31, 2006 | 03:57 PM
fuzzie's Avatar
Default Re: OBD1 conversion vtec wiring help (Concept Tuning)
the black plug is the oil pressure plug..the green one is a vtec solenoid plug
Old Apr 2, 2006 | 11:37 PM
ALLMOTORCRX20's Avatar
VTEC SOLENOID-BLACK PLUG- 1 WIRE -----> A4 on ECU
VTEC OIL PRESSURE-GREEN PLUG- 2 WIRES------> (blue wire to D6 on ECU)
(black wire to ground)
Old Apr 3, 2006 | 06:55 AM
Default Re: OBD1 conversion vtec wiring help (ALLMOTORCRX20)
Anyone else want to chime in? These guys are telling me two different things.
Old Apr 3, 2006 | 12:34 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTORCRX20 &raquo;</TD></TR><TR><TD CLASS="quote">VTEC SOLENOID-BLACK PLUG- 1 WIRE -----&gt; A4 on ECU
VTEC OIL PRESSURE-GREEN PLUG- 2 WIRES------&gt; (blue wire to D6 on ECU)
(black wire to ground)</TD></TR></TABLE>
correct
Old Apr 3, 2006 | 02:01 PM
Default Re: OBD1 conversion vtec wiring help (droppedcrxsi)
Thanks!
Ok now one more question. I have a 4 wire O2 coming in. On the conversion harness it says only two of the wires go to the O2 sensor though, so what about the other two wires?
Old Apr 3, 2006 | 09:09 PM
Rywire's Avatar
the 4 wire o2 is easy
-signal (you can use the stock wire)
-ground
the 2 wire that are the same can interchange...
-heater A6 (obd1)
-12V+
Old Apr 4, 2006 | 06:49 AM
Ok I'm confused.
So one is a ground
One I just use the wire from my 1 wire O2?
One is heater and 12v+ which is what the conversion harness connects to?
Old Apr 4, 2006 | 02:10 PM
Rywire's Avatar
Give me more info, what ecu jumper do u have, and what colors are on your o2...
Old Apr 4, 2006 | 04:34 PM
I have the ECU jumper I got from eGay. I talked to you before about the dizzy wiring and you said it was the same way you did yours.
I havn't got the O2 yet. Should be coming in Friday. Trying to get eveything ready so I can get it done quick and cleanly without any problems.
Old Apr 4, 2006 | 09:03 PM
Rywire's Avatar
ok, just post up the o2 colors, and I will try and do a how to for ya
Old Apr 10, 2006 | 10:37 PM
You probably bought the same obd-0 to obd-1 conversion harness that I bought on ebay. If im right, I feel bad for you. The instructions that guy put were messed up and he didnt even pin one of the wires correctly. I had to troubleshoot it to get it right. Here is some info that might be of some use to you.
There are 4 wires on the oxygen sensor itself
WHITE
GREEN
BLACK
BLACK
There are 4 wires going from the harness to the sensor
WHITE
GREEN
YELLOW
ORANGE
The way the colors go are
WHITE-----&gt;WHITE This is signal, A14 or D14 on ECU
GREEN-----&gt;GREEN Ground
YELLOW----&gt;BLACK 12 Volts
ORANGE----&gt;BLACK I think this one is 12 Volts too
on the plug, i believe they go
(clip)
WHITE ---- GREEN
YELLOW ---- ORANGE
Old Apr 11, 2006 | 05:20 AM
^ ummm no the one I bought only has two wires to the O2. It also had good instructions, however some of the stuff it named I didn't know the difference. I would have bought a Rywire, but this guy copied his and sold it for $45 shipped.
Anyways, I will post of pics of the O2 later. I can't get my old one out of my header now. Go figure the one wrench I need (22mm) is the only one I can't find.
Old Apr 12, 2006 | 10:14 PM
I bought mine for 45 bucks too on ebay. I think its the same one. You can also use the 7/8 wrench to take off the oxygen sensor, that's the one i use.
Try and scan the instructions and post them here and i will try and help you out. Also, take a picture of the conversion harness.
Old Apr 13, 2006 | 12:08 PM
I got the O2 wiring done, thanks to Rywire Also gave me a killer deal on some plugs, thanks man.
I'm not getting any codes. Not sure if I have the temp vtec wired up right. Didn't feel it or hear it.
The car doesn't smoke or anything like it does when I was still running the PM6. It is a hella-of-a-lot faster too. Now next issue....handling (see other thread)
Graves87
May 14, 2008 02:02 PM
1995eg
Oct 3, 2007 06:12 PM
allsho
Jun 14, 2007 12:06 PM
leroyb
Apr 13, 2007 03:15 PM
.Eddie
Mar 10, 2007 09:49 AM
