Del Sol Distributor bearing - worn out!
Old Mar 29, 2006 | 11:26 PM
sciclunam's Avatar
Default Del Sol Distributor bearing - worn out!
Hi Guys. First time here, and first time driving a Honda! Cool!
I took my just acquired car to a local garage because of a noise coming out of the distributor. He told me that the distributor bearing, above the oil seal is damaged.
I can't locate one here. Do you have any idea where I can get hold of this part?
I forgot to tell you that my Del Sol is a 1992 1.5L Vtec engine.
Thanks a lot.
Mario
Modified by sciclunam at 5:29 AM 4/1/2006
Old Mar 30, 2006 | 04:28 AM
EE_Chris's Avatar
Default Re: Del Sol Distributor bearing - worn out! (sciclunam)
You can't buy just that part - you have to get the whole distributor sub-assembly, which is like $250.
Or you can try Distributor King and just get a whole brand new distributor for around that same price.
Old Mar 30, 2006 | 05:07 AM
sciclunam's Avatar
Default Re: Del Sol Distributor bearing - worn out! (EE_Chris)
Thanks.
I am getting the impression that Distributor King are well renowned, right?
Old Mar 30, 2006 | 12:09 PM
-Gary-'s Avatar
I had the same problem with my '92. I sure wasn't cheap from Honda...
Old Mar 30, 2006 | 12:14 PM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sciclunam &raquo;</TD></TR><TR><TD CLASS="quote">Thanks.
I am getting the impression that Distributor King are well renowned, right?</TD></TR></TABLE>
yes and you get good discounts if you tell them you are a member on honda-tech
i think you need this assembly: honda oem pn 30100-P08-006 DISTRIBUTOR ASSY. (TD-42U) (TEC)
Old Mar 30, 2006 | 12:44 PM
civic93@8psi's Avatar
Default Re: Del Sol Distributor bearing - worn out! (Del Sol SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del Sol SiR &raquo;</TD></TR><TR><TD CLASS="quote">
i think you need this assembly: honda oem pn 30100-P08-006 DISTRIBUTOR ASSY. (TD-42U) (TEC) </TD></TR></TABLE>
DAYM THAT PART NUMBER LIST FOR 567.27
Old Apr 1, 2006 | 08:01 AM
sciclunam's Avatar
Default Re: Del Sol Distributor bearing - worn out! (civic93@8psi)
Thanks guys
thordain
Nov 20, 2010 09:08 PM
Motown Del Sol
11
Sep 6, 2009 05:48 AM
kiana60
Aug 3, 2009 05:46 PM
