question about a ZC engine.
I have a 91 CRX with a ZC sohc non vtec motor. If i were to buy a d15b motor to replace my ZC sohc that would bolt right up with the tranny and everything?
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 »</TD></TR><TR><TD CLASS="quote">ive never heard of a SOHC ZC motor i thought ZC's are DOHC</TD></TR></TABLE>
ZC newb hahah, but ya any D series will go right in
dont reply if u dont know what ur talking about..there are 3 zc engines...1 sohc non vtec...a sohc vtec and a non vtec dohc...if u wana go from a sohc zc non vtec to a d15 b nonvtec....ur all good...but if u go with the d15 vtec, tranny..axles evereything will work but ur gona have to do lil bit of wiring..for the vtec and such..
if vtec...new ecu and obd1 conversion needed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoHcZC91si »</TD></TR><TR><TD CLASS="quote">dont reply if u dont know what ur talking about..</TD></TR></TABLE> He didn't spread false ideas as fact, so don't be mean
There were also more then just three types, we can start going into OBD levels and Fuel Injected and Carb'd models
no really im not tryin to spread false ideas, as far as i know that is a FACT, a ZC motor is JDM DOHC motor, the only equivalent of that is the motors that came in 86-89 integras, nothing else is a ZC, ZC's are DOHC how can u say SOHC are the same thats like sayin B18s are the same as a SOHC non VTEC correct, thats just by going by some of the engine code charts that are on here on HT, and also seriously read the motor code on the block does it at all say ZC anywhere??? ....check it out for yourself... (scroll down to the engine codes, 5th one is the ZC motor) https://honda-tech.com/zerothread?id=642479
There are a bunch of zc engines..Come in sohc,sohc vtec,and dohc..Some have fuel injection ,,some have carbs..The earlier ones I belive had the brown valve cover,,and most ones you see have the black valve covers..They come in integras,civics,crx's from I think years 84-95..Im no expert on the zc engine though..Check out http://Thezcr.com for some info
**** just last year when I went to my home country,, I saw a 94 integra with a sohc zc with carbs..bone stock..
my question once again, what does the engine code read on the block??? i gaurantee it does not say ZC, therefore it is not a ZC just people started callin it that ,there is only ONE ZC motor and ONE motor that is similar to that which is the motor that came in 86-89 integras like i said.
A ZC SOHC Vtek is a JDM version of the D16Z6. It has ZC stamped on the block.
I have two of them in two different cars.
They are D series engines so the tranny from another D series will bolt right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 »</TD></TR><TR><TD CLASS="quote"> i gaurantee it does not say ZC</TD></TR></TABLE>
What do I get with your gaurentee?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 »</TD></TR><TR><TD CLASS="quote">that makes a bit of sense to me, the way everyone is talkin is as if there in all kinds of cars, cool beans
They are,dont really go by hmotors for zc info....They come in jdm 84-95 civics,crxs,delsol,and integra..They come in both carb and fuel injection,and in dohc,sohc,and sohcvtec..Like I said Ive seen them all personally except the old brown top zc..
</TD></TR></TABLE>They are,dont really go by hmotors for zc info....They come in jdm 84-95 civics,crxs,delsol,and integra..They come in both carb and fuel injection,and in dohc,sohc,and sohcvtec..Like I said Ive seen them all personally except the old brown top zc..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 »</TD></TR><TR><TD CLASS="quote">my question once again, what does the engine code read on the block??? i gaurantee it does not say ZC, therefore it is not a ZC just people started callin it that ,there is only ONE ZC motor and ONE motor that is similar to that which is the motor that came in 86-89 integras like i said.</TD></TR></TABLE>
u made me laugh. hahahaha. ONLY ONE ZC???? get ur facts straight.
hahahaha
... ive never seen one and only heard of the DOHC ZC motor thats it, never seen any civic integra or del sol stamped with a ZC on the lbock.
the sohc zc dont have zc stamed on the block.it says d15b,sohc vtec<<<only sohc zc made.dohc zc came out of many diff cars.crx civic,<<<jdm or edm they also came in few rovers cars too.<<rover doesnt have zc stapmed on the block it says d16a8.only jdm zc says zc on the block.the bron top zc(88/89 teggie engine.thats the weak zc.<<<junk i would have to say from personal adivce the d15b is fastest one of all the zc motors.they made a obd1 dohc zc which came in the eg hatch and desols.
OK, perhaps some people cannot read...
I personally have 2 SOHC Vtec ZC motors and (For the last time) they are both stamped ZC on the block.
Mine are the JDM version of the USDM D16Z6 is stamped ZC on the block. The only difference between the two engines is that the JDM engine has a little higher compression and a few more horse power.
Both of my motors were purchased from HMotors, and they deal specifically in JDM engines.
Sheeeesh...
Sheeeesh...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc »</TD></TR><TR><TD CLASS="quote">the sohc zc dont have zc stamed on the block.it says d15b,sohc vtec<<<only sohc zc made.dohc zc came out of many diff cars.crx civic,<<<jdm or edm they also came in few rovers cars too.<<rover doesnt have zc stapmed on the block it says d16a8.only jdm zc says zc on the block.the bron top zc(88/89 teggie engine.thats the weak zc.<<<junk i would have to say from personal adivce the d15b is fastest one of all the zc motors.they made a obd1 dohc zc which came in the eg hatch and desols.</TD></TR></TABLE>
No,,You are confused ..ZC motors have "ZC" stamped on the block..If it has something else stamped on the block it is not a zc engine,even if its basically the same engine besides the zc stamp vs/ d16 stamp..Period..And like I said before there are a shitload of different zc engines that have ZC stamped right on the block..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 »</TD></TR><TR><TD CLASS="quote">hahahaha
... ive never seen one and only heard of the DOHC ZC motor thats it, never seen any civic integra or del sol stamped with a ZC on the lbock.</TD></TR></TABLE>
Yeah thats because your in the usa..If you go to a country that gets jdm cars you'll see them..
hum?the d15b is sohc vtec zc and it says d15b on the block not zc.yea i know there many differant zc with zc stamped on the block.my zc donty say zc.i thought only jdm dohc zcs says zc.cause the edm zc say d16a8/9 and have the same excat valve cover as the jdm zc
