spark plugs for turbo set up
Old Mar 29, 2006 | 07:56 PM
willie_d18's Avatar
Default spark plugs for turbo set up
i got a 96 dy18 with a turbo set up and full msd set up. what kind of plugs should i use with this
Old Mar 29, 2006 | 07:59 PM
97spooncivic's Avatar
Default Re: spark plugs for turbo set up (willie_d18)
1 or 2 steps colder. NGK
posite's Avatar
ngk bkr7e gapped .03
Old Mar 29, 2006 | 08:01 PM
Sliced Beard's Avatar
Default Re: (posite)
I would go with a bkr8e and a larger gap such as a .034-.036"
it is a hotte plug but it sounds to me that you are running a stock bottom enf and lower boost. You could benefit from a hotter plug if you are running under 7psi.
Old Mar 29, 2006 | 09:50 PM
willie_d18's Avatar
Default Re: (DirtySol)
I WANT TO ATLEAST RUN 10, BUT FOR NOW IMA RUN 7PSI , SO 8E SHOULD STILL BE GOOD RIGHT
Old Mar 29, 2006 | 10:44 PM
H.A.R.T B18C1EG6's Avatar
Default Re: (willie_d18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by posite &raquo;</TD></TR><TR><TD CLASS="quote">ngk bkr7e gapped .03</TD></TR></TABLE>
i run the same NGK plugs
willie_d18
Mar 17, 2006 05:43 PM
staticchmbr
Jan 14, 2006 07:29 AM
tuoniz
Aug 16, 2005 11:30 AM
TurboBumblBee
Sep 1, 2003 11:01 AM
808eg6
Jan 25, 2002 07:03 AM
