Many B16 Tranny Questions
Old Mar 29, 2006 | 07:39 PM
Ninja Mike's Avatar
Default Many B16 Tranny Questions
So I am installing a 98+ ITR LSD in a S4C, 00' B16A2 tranny.
The ITR LSD bearings spin freely but make a minor scraping noise. Should they be replaced?
My stock differential bearings spin freely and make NO scraping noise. Could I use these if the ITR LSD bearings need to be replaced?
Old Mar 29, 2006 | 07:50 PM
IN VTEC's Avatar
Default Re: Many B16 Tranny Questions (SleepEMike)
Add a little MTF to the bearing and recheck. A dry bearing will chafe some when you spin them.
Old Mar 29, 2006 | 07:57 PM
Tuesday Club's Avatar
Default Re: Many B16 Tranny Questions (IN VTEC)
^what he said
Old Mar 29, 2006 | 07:58 PM
Ninja Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Add a little MTF to the bearing and recheck. A dry bearing will chafe some when you spin them.</TD></TR></TABLE>
Thanks, I'll try that. You are likely right b/c the ITR parts have been sitting for a while. I moment of relief b/c the bearings are $50 a pop to replace.
Old Mar 29, 2006 | 08:31 PM
Ninja Mike's Avatar
NEW Question:
I put the ITR LSD into the S4C tranny case, but I can't seem to take it back out. Is there a special trick or method? The helms doesn't even specify how to remove the stock one. My friend waled on the middle bar in the stock one with a screwdriver and it pulled right out.
LocoJoe
Transmission & Drivetrain
Mar 2, 2011 06:55 PM
spinney
Aug 16, 2005 02:23 PM
mingchi69
Feb 17, 2004 09:39 AM
cr00klyn718
Apr 28, 2002 03:38 AM
