[ATTENTION] GSR CLUSTER SWAPERS
Well guys i just swapped my GSR cluster in my 95 Civic..
everything is working right except..
the turn signals and the TACH
The Tach works fine up to 3k and then stops..... and then when the rpms come back down it will work just fine... but it wont go above 3k
I need to find out what is wrong
PLEASE help
PLEASE help
it sounds like there is something rubbing on the tach needle. do you have gauge faces or indiglos on it?
the turn signals... you have two wires wrong. Or the ground is bad causing both problems.
mugenhatch92
Mar 29, 2006 07:21 PM
