how to swap dx to ls
Old Mar 29, 2006 | 04:32 PM
bobbyg crxh22's Avatar
Default how to swap dx to ls
ok need help....first time swaper....yes i know that i need to change the wiring....but i'm not sure how to do it..and i looked at a hole bunch of ****....i would really like some help with that if you guy can...and i was wondering if i could just change the hole wiring to si...or does it just not work like....please help..oo yea and i'm going from obd0 to obd1...converison plug thing would work right..please help
Old Mar 29, 2006 | 04:37 PM
cbp_crx's Avatar
Default Re: how to swap dx to ls (CRX DX 2 LS BobbyG)
hey man whats up, im repping iowa too, im down in knoxville, for the wiring best thing to do if you dont feel that you can do it yourself is to have someone else do it, one of the most respected people on here is droppedcrxsi his website is
http://www.rywire.com many people can vouch for him
Old Mar 29, 2006 | 04:46 PM
Default Re: how to swap dx to ls (cbp_crx)
yea i went to there website..before and like you still have to wiring somethings...like something to the ecu..and is that hard...i mean i don't know wiring at all...this will be one of the things that will be holding me back..and i think tha will be it and its going to **** me off....i know some kids that can wiring vtec around here but i don't want to pay them...i kinda would like to do this on my own...so that i know how to do it...but is it hat hard...the ecu part...
Old Mar 29, 2006 | 04:48 PM
cbp_crx's Avatar
no its not hard at all, just depin a couple wires at the ecu and swap them around, if you couldnt figure it out, i could come up and do it for free
Old Mar 29, 2006 | 04:49 PM
ok after that part of the wiring is done what do i do for obd0 to obd1
Old Mar 29, 2006 | 04:50 PM
cbp_crx's Avatar
also someone correct me if im wrong, but i think they also have a product now that you plug your ecu harnesses into it, and then plug the other end into the ecu, so you dont have to depin
Old Mar 29, 2006 | 04:51 PM
cbp_crx's Avatar
best way is just to get a obd0-obd1 coversion harness, it might seem like a lot of cash for wiring, but its best to have it done right the first time, so you arent chasing down wiring problems later
Old Mar 29, 2006 | 04:55 PM
yea is said something about th dizzy and i'm guess i need that too...
Old Mar 29, 2006 | 04:58 PM
cbp_crx's Avatar
from rywire, that part is also done,
Old Mar 29, 2006 | 05:04 PM
crxnj's Avatar
Yeah if you're not good with wiring you can basically have a place like rywire do everything for you can all you need to do is hook it up..
You can try it yourself though..Here are some writeups
obd0-obd1 =
https://honda-tech.com/zerothread?id=1319235
https://honda-tech.com/zerothread?id=1520516
dpfi to mpfi =
http://crf50.no-ip.com/fourthgenhatch/mpfi.html
Old Mar 29, 2006 | 05:07 PM
yea i'm going togo with rywire on that stuff....do you know if i need anything else for the swap i know..motor mount....shift linkage....axle.....what kinda of axles do i need...and thats all i can think off yea ecu too...but after that i dont know....
Old Mar 29, 2006 | 05:09 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX DX 2 LS BobbyG &raquo;</TD></TR><TR><TD CLASS="quote">yea i'm going togo with rywire on that stuff....do you know if i need anything else for the swap i know..motor mount....shift linkage....axle.....what kinda of axles do i need...and thats all i can think off yea ecu too...but after that i dont know....</TD></TR></TABLE>
What year is the swap..?
Old Mar 29, 2006 | 05:49 PM
Rywire's Avatar
Default Re: how to swap dx to ls (Mr.speaker)
match the int shaft withthe axles. Best bet is 90-91 integra axle setup
Ryan
Old Apr 1, 2006 | 08:56 AM
Default Re: how to swap dx to ls (droppedcrxsi)
crx 88 dx
i thought the axle i need what 89 axles
Old Apr 1, 2006 | 10:50 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX DX 2 LS BobbyG &raquo;</TD></TR><TR><TD CLASS="quote">crx 88 dx
i thought the axle i need what 89 axles </TD></TR></TABLE>
No,,For passenger side you need any b-series axle..For driver side you match the axle wit the halfshaft..So if you have a 90-93 integra halfshaft get the 90-93 axle..If you have the 94-01 halfshaft get the 94-01 integra axle..Also remember to remove the little dust rings from inside the hubs,otherwise the axles will bind..
Old Apr 1, 2006 | 10:59 AM
can i just buy this somewhere
Old Apr 1, 2006 | 11:07 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX DX 2 LS BobbyG &raquo;</TD></TR><TR><TD CLASS="quote">can i just buy this somewhere</TD></TR></TABLE>
You mean the axles..? Just got to a autoparts store,,napa,autozone,advancedauto,pepbpys,rockauto .com,ebay,etc..
Old Apr 2, 2006 | 11:00 AM
ok cool..
Old Apr 4, 2006 | 07:33 PM
MJobe's Avatar
haha bobby finally going to the "B"
Old Apr 5, 2006 | 08:51 AM
ClubRX's Avatar
Hey Bobby do what Josh K. did, take your motor out and unplug all the wires from the motor and do the same to the motor when you get it, put the 2 harneses in a box with the Hasport order form which you can print it off and the send into hasport. The total is gunna be $214 but they send you back instructions and its very simple and Josh and I could help you because him and i did this to his car which is a dx. And I dont know why Tony and everybody thinks you have to get an 89 integra axle cuz you dont do that! You just take off your dust cover and on ur hub and it will work perfect and I know how ta do that too. Actually just check my topics Ive crreated about dx to ls it answers all ur questions.
Old Apr 5, 2006 | 08:55 AM
ClubRX's Avatar
Oh ya you need a new throttle cable its the stock off whatever motor ur gunna swap. Dont get cheap and get the custum bracket that lets you use ur stock dx throttle cable that is bad. Lets unplug all the wires today brotha!
Cuninlyngus
Apr 2, 2015 08:38 AM
sleeper17
Dec 9, 2008 07:08 PM
1DA94u2NV
Jun 7, 2006 07:37 PM
