radiator leak?
Old Mar 29, 2006 | 04:05 PM
B bOy CrAyOn's Avatar
Default radiator leak?
i have a 93 hatch wit jdm b16 2nd gen swap... with full bolt ons... except for throttle body.....i filled up my radiator and my resivoir tank with coolant..... after every time i pop the hood my resivoir is always empty.... i checked my friends gsr and he had coolant sitting in his resivoir tank... is this normal to have no coolant in the resivoir tank or do u think i have a leak?
but my car doesnt overheat or anything ... i just never have coolant in the resivoir
Old Mar 29, 2006 | 04:27 PM
ekcivic9's Avatar
did you install a new radiator?
i did replaced my radiator a month ago, and for 3 wks, the levels kept dropping, and i just kept adding coolant... right now it doesnt drop anymore.
i think it just needed time to circulate through the whole system since i flushed it.
Old Mar 29, 2006 | 04:59 PM
nah the same old radiator thats been in it it for a year or so
Old Mar 29, 2006 | 05:16 PM
Syndacate's Avatar
well fill some in the res and check it in a week and see if it's still there..
THen you know it's not a leak
Old Mar 29, 2006 | 05:40 PM
ek_chris's Avatar
did u recently do a flush?
you may have a leak.. id top it off with coolant and check after a good drive and check when it cools down
Old Mar 29, 2006 | 06:13 PM
Sliced Beard's Avatar
Default Re: (ek_chris)
I am willing to bet that the resivior is leaking.
Honda did a really shitty job of mounting them and they vibrate during driving. Ususlly, when the plastic gets old, they tend to get brittle and crack. When they crack, every bit of coolant in the bottle will leak out.
Old Mar 29, 2006 | 06:14 PM
devoxtekxhb's Avatar
Default Re: radiator leak? (B bOy CrAyOn)
are you checking the resevoir while the engine is still warm?
Old Mar 29, 2006 | 06:27 PM
ill do all this stuff tomorrow and find out whats goin on.... ive pulled the resivoir out and filled it up and nuthing leaked....
98hatchhonda
Honda Civic (2001 - 2005)
May 15, 2016 01:38 AM
crxaddikt
Mar 25, 2014 11:00 PM
dunkd
Jul 12, 2006 07:15 PM
ALLMOTORD16Z6
May 20, 2005 03:27 AM
PatrickGSR94
Jan 24, 2003 08:26 AM
