VX vs CX options/specs
Old Mar 29, 2006 | 03:40 PM
b18c1del's Avatar
Default VX vs CX options/specs
new in import scene > dunno diff between VX or CX h/b
HELP HELP w/ which is better/lighter easier to work with
Old Mar 29, 2006 | 03:47 PM
skater4145's Avatar
Default Re: VX vs CX options/specs (b18c1del)
i would also like to know
Old Mar 29, 2006 | 03:50 PM
Lewy. Dee Ayy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1del &raquo;</TD></TR><TR><TD CLASS="quote">new in import scene &gt; dunno diff between VX or CX h/b
HELP HELP w/ which is better/lighter easier to work with </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=150315
theres weight diff's..and i say CX is better..but thats just because i have one....
Old Mar 29, 2006 | 03:53 PM
jonny_sin's Avatar
actaully the cx is the lighter of the hatch by about 400 pounds so i would go with the cx
astroxtc's Avatar
i dont know much between the cx/vx but i know the vx gas a crap load of gas, and is sohc vtec? 92hp and cx is 70hp
Old Mar 29, 2006 | 03:56 PM
bmoua's Avatar
well ive heard that doing a swap on a VX is easier than a cx becuz the vx has the vtec wiring...it has vtec-e...some one correct me if i'm wrong....
Old Mar 29, 2006 | 04:12 PM
astroxtc's Avatar
Default Re: (bmoua)
Originally Posted by B18C5-EH2
Okay, I see a lot of posts about vehicle weight and the differences between the various CX, VX, DX, and Si models.
I'd like to set this **** straight so nobody else is confused.
First of all thanks to Shawn Hayes here on H-T for hooking me up with the 1992 Civic sales brochure, which had all the specs for every 1992 Honda Civic available, meaning hatchbacks and 4-doors only since the coupe wasn't offered until 1993.
Anyways, here go the base weights as measured by Honda in 1992:
1992 Honda Civic:
CX hatchback: 2094lbs.
VX hatchback: 2094lbs.
DX hatchback: 2178lbs.
Si hatchback: 2326lbs.
So that's the weights of each vehicle STOCK.
Notice the exact same weight for both the CX and VX? This should dispell those "VX is the lightest" arguments. In fact, in theory would you not think the CX would be even lighter since the VX had light-*** alloy 13 inch wheels while the CX had heavy-*** steel wheels? This would leave me to believe a few different things:
Body for body (which matters more because you swap out the wheels anyways, I mean 13'' wheels, come on!) I think this may mean the CX is lighter still. The only thing I can think that would make the VX the sane weight but has much lighter wheels might be that the VTEC-E motor weighs more than the CX 8-valve motor.
Another thing is the gas tanks.
CX and VX has a 10 gallon tank, while the DX and Si have the 11.9 gallon tank. Keep in mind these specs are striaght from Honda, so regardless how much gas you've squeezed in your CX, VX, DX, or Si it dosn't matter. Honda probably only measures TANK volume, not the filler and what's already in the fuel lines, etc.
So you also see that the DX is 84lbs. more than the CX/VX. Why would this be? Here's what I came up with:
Bigger fuel tank - tank is steel, so bigger = heavier
Rear wiper/washer
More tar - seen it myself. DX has more tar than the CX/VX.
Side moldings - plastic, but still weighs more than the non-existent side moldings on the CX/VX
Rear cargo cover std. it weighs something, right?
That just might be the difference. Things like the cargo cover and tar, rear washer/wiper can be deleted to get closer to CX/VX, so it's not a huge deal.
You also see that the Si is one heavy PIG compared to it's other hatchback brothers.
One more hilarious thing here for you guys with Si hatches that say "coupes are heavy, that's why I have a hatch" which I see often, and used to say myself.
How's this strike you:
1992 Civic 4-door with manual tranny:
DX 4-door: 2275lbs.
LX 4-door: 2319lbs.
Why did I bold the LX 4-door weight?
Because it has power windows, doorlocks, cruise control, power steering, etc. and is STILL lighter than the Si hatchback! So what do you think of the coupes now? If the 4-door is lighter, what about the 2-door coupes? The DX coupe is a good deal lighter than the Si hatchback.
Don't get all pissy if you own an Si - I used to have one, but after getting beaten by others in CX, VX, and DX hatches with less whp I sold it to build up a CX hatchback.
So, does anyone else on H-T here have this kind of info on the 1994-1995 hatchbacks? I know they weigh more because they added another airbag in 1994-1995, and some Si hatches came with ABS too. All that **** adds weight.
One last thing to keep in mind here:
These cars were weighed BONE STOCK.
This means:
No A/C - was NOT std. on any hatchback in 1992
No radio - again radios were NOT std. on ANY hatches in 1992
Only Si had 2 mirrors std. Add the weight of a mirror if you got 2 on your CX/VX/DX
ONLY the Si had powersteering - the DX auto did too, but I didn't list that one. I listed the manual, which had no p/s
Stock wheels. VX had lightweight 13'' alloys, CX/DX had 13'' steels, Si had heaviest 14'' steelies with wheel covers
So think about all those things that we can take out of our cars to get the weight down. This gives you a basic idea of what your car should weigh with no A/C, p/s, etc.
Also think about what ADDS weight to your car. Stereo, SWAP, bigger brakes, swaybars, bigger wheels, strut bars, etc. So don't think your 1992 CX weighs 2094lbs. if you have 2 mirrors, A/C, radio, SWAP, etc. You might be over the stock weight.
What are your thoughts on this guys?
[Modified by B18C5-EH2, 11:58 PM 3/22/2002]
Old Mar 29, 2006 | 04:15 PM
schardbody's Avatar
thats easy, theres no arguement, VX is the best starting point, unless its a 92 cx then there equal. they weight the same regardless of what people say, and the VX is prewired for vtec.
Old Mar 29, 2006 | 04:21 PM
astroxtc's Avatar
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">well ive heard that doing a swap on a VX is easier than a cx becuz the vx has the vtec wiring...it has vtec-e...some one correct me if i'm wrong....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">VTEC-E is a twist on the regular VTEC mechanism. Whereas VTEC's purpose can be more or less summarized as: extracting high RPM performance while maintaining smooth low RPM operation, VTEC-E can be summarized as: allow extremely lean fuel-air mixture at low RPMs in order to increase fuel economy. In other words, VTEC technology is used to optimize different ends of the RPM range in the two different implementations </TD></TR></TABLE>
Old Mar 29, 2006 | 04:24 PM
BauleyCivic's Avatar
Risky Business
Default Re: (astroxtc)
He's right though. Even though its VTEC-E, the wiring is still there for the solenoid and oil pressure switch.
Old Mar 29, 2006 | 04:28 PM
schardbody's Avatar
and alot of the parts for a D16z6 or jdm D15b swap are already there, like dizzy, vtec solenoid, wiring, etc... where as with the cx you need that stuff for the new D series. the only thing i dont like about the vx is the 5wire oxygen sensor. it seems like they are a million bucks and after buying 2 used ones that were also bad i dont recommend it.
Old Mar 29, 2006 | 04:48 PM
ludesrv's Avatar
The VX is by far the best. Lightest of all hatches (maybe the Cx is the same?) but it already has wiring for Vtec, so swaps are easy and cheap, no wiring needed. Best part is, the stock motors get 600kms per tank of gas on the cheapest gas you can feed it on a tune up aswell.
Buy the Vx.
Old Mar 29, 2006 | 08:16 PM
b18c1del's Avatar
thanks for the facts &gt; helps w/ my decision to buy a front end damaged vx
Old Mar 29, 2006 | 08:21 PM
egcivicb16's Avatar
VX!
Old Mar 29, 2006 | 08:22 PM
Lightweight Boost's Avatar
always believed the cx was 14lbs heavier at 2108 because of the use of steel wheels unlike the vx ultra light wheels ?
malibu2000
37
Dec 3, 2007 11:34 AM
CapnKrunch
Nov 17, 2006 12:53 AM
driftrx7
Apr 13, 2006 04:39 PM
kid-honda
Nov 5, 2003 07:47 PM
Desperado
Apr 8, 2003 06:35 PM
