B16/header question
Old Mar 29, 2006 | 02:07 PM
T3k C's Avatar
Default B16/header question
I got this B16 and it came with an unknown stock header. Now how can i tell what this header came out off? because I am trying to get a cat converter and I think im suposed to know what is my header from... so that the cat will bolt up.Am i thinking in the right direction?
By the way, I compared my header with my brother's b18a header and mine is shorter than is.. if that helps any. Somone HELP!
Old Mar 29, 2006 | 04:12 PM
Crx Jimmy's Avatar
Default Re: B16/header question (B16DSEF)
then you have a gsr header, b18 ls, and type r, and del sol b16, and 99 si, are the same size only the gsr is shorter
Old Mar 29, 2006 | 04:27 PM
category5 SI's Avatar
Default Re: B16/header question (Crx Jimmy)
the flange at the collecter on the b16 header is turned in a different position then the b18 header.
Old Mar 29, 2006 | 07:39 PM
T3k C's Avatar
So I should look for a cat converter for an integra, am i right?
Would a gsr stock header fit on like a b16?
Old Mar 29, 2006 | 07:43 PM
Crx Jimmy's Avatar
Default Re: B16/header question (category5 SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by category5 SI &raquo;</TD></TR><TR><TD CLASS="quote">the flange at the collecter on the b16 header is turned in a different position then the b18 header.</TD></TR></TABLE>
Wrong , i have a dc header for a b18 and for a 99si and the flange is turned the same way
Old Mar 30, 2006 | 06:54 AM
T3k C's Avatar
^^^ Still need to know what cat...
Old Mar 30, 2006 | 08:16 AM
soulassasincc's Avatar
just run straight down pipe
Old Mar 30, 2006 | 10:24 AM
T3k C's Avatar
&lt;&lt; Need cat.
Old Mar 30, 2006 | 01:17 PM
aaronhume's Avatar
Default Re: (B16DSEF)
hmm i have a gsr header and it doesn't clear my oil pan on my b16a so it may not be that one (the header i have is a 00 gsr) you might need custom exhaust work done no matter what though.... then you could use an old catalytic converter from the d series engine... thats what I have when I need to run my cat, the rest of the time i use a straight pipe, ebay special!
blk_eg4
Jun 17, 2007 05:19 PM
durrett syndrome
Jul 24, 2003 07:56 PM
tegrevboy
Dec 16, 2002 08:18 PM
