h22 into eg help!
Old Mar 29, 2006 | 01:24 PM
makelove2hondas's Avatar
Default h22 into eg help!
hey just put an h22A into my 92 civis si, the problem is that it falls on its face anytime u try to accelerate and i can not figure the problem out, idles fine and no check engine lights so i don't know, I just keep trying things, but anyway I am using the stock fuel pump that was in the 92 si, could that be the problem? thanks
Old Mar 29, 2006 | 02:54 PM
Specail Ed's Avatar
Default Re: h22 into eg help! (makelove2hondas)
The stock fuel pump will handle H. What ECU are you running and did you hook up the injector resistor?
Old Mar 30, 2006 | 08:42 AM
Default Re: h22 into eg help! (Specail Ed)
p13 and yea got the resistor box hooked up any ideas would be great help
Old Mar 31, 2006 | 02:51 PM
bump need help
Old Mar 31, 2006 | 07:41 PM
BALLIN H22 EK's Avatar
swap out another resistor box the one u got might be bad
Old Apr 2, 2006 | 12:13 PM
Default Re: h22 into eg help! (BALLIN H22 EK)
wouldn't the engine not run, or the ecu get fried if that happend?
Old Apr 2, 2006 | 12:48 PM
if the resistor box went out it will go into limp mode or cause it to die quite possibly
Old Apr 2, 2006 | 04:41 PM
like die as in, it has no power and when u press the pedal down it boggs real bad and spits and sputters?
Old Apr 3, 2006 | 02:26 AM
bumpage
Old Apr 3, 2006 | 05:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makelove2hondas &raquo;</TD></TR><TR><TD CLASS="quote">like die as in, it has no power and when u press the pedal down it boggs real bad and spits and sputters?</TD></TR></TABLE>
check ur altenator wire and make sure it has a good connection maybe ur loseing power there
Old Apr 3, 2006 | 06:24 AM
2point2's Avatar
do you have all new ignition components? (wires, plugs etc..)
Old Apr 3, 2006 | 07:00 AM
IHateJDM's Avatar
Default Re: (2point2)
sounds like cam timing is off a tooth to me.
Old Apr 3, 2006 | 08:24 AM
Default Re: (IHateJDM)
just installed new plugs and wires, the other ones didn't look bad but i did it anyways, i think it would run on battery power if i lost alternator power, the timing belt was just changed but i will look into that though. i kept getting an o2 code, the old plugs were black so that means its rich, haven't got the o2 code but haven't taken it out since i cleared the code. thanks guys anymore help would be great
Old Apr 4, 2006 | 05:48 AM
Default Re: (makelove2hondas)
bump
Old Apr 5, 2006 | 04:17 PM
poison's Avatar
Have you checked the TPS voltages? check that by hooking a multimeter to the ground and middle wire. put the ignition on the "on" position w/o the engine started and check voltage.
make sure it's .45 to .5v at idle and 4.5 volts at wot.
check your MAP sensor vacuum lines, and the map sensor runners between the throttle body and intake manifold as well. i would recommend cleaning it all.
Old Apr 6, 2006 | 05:42 PM
Ministry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makelove2hondas &raquo;</TD></TR><TR><TD CLASS="quote">the timing belt was just changed</TD></TR></TABLE>
meaning... the car has been doing this ever since the timing belt was changed?
Old Apr 6, 2006 | 07:41 PM
Default Re: (dreamer)
yea bc it was changed before the engine was put in and started
Old Apr 7, 2006 | 05:21 AM
Ministry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by makelove2hondas &raquo;</TD></TR><TR><TD CLASS="quote">yea bc it was changed before the engine was put in and started</TD></TR></TABLE>
one more time: has the motor ever functioned properly since the belt change? or has it been doing this ever since the belt change?
Old Apr 7, 2006 | 05:32 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">sounds like cam timing is off a tooth to me.</TD></TR></TABLE>
yep. starting to look like that.
sometimes it will feel like your engine is running right, but with a very shitty cam if your belt timing is off.
Old Apr 7, 2006 | 08:52 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
sometimes it will feel like your engine is running right, but with a very shitty cam if your belt timing is off.</TD></TR></TABLE>
Old Apr 7, 2006 | 01:48 PM
Default Re: (skunked)
nope i got it with the timing way off so my friends decided to put the water pump timing belt on when i wasn't there, it starts and idles fine but just can't catch up to it self, no power at all, i think its the timing too bc i have checked everything
Old Apr 7, 2006 | 01:49 PM
thanks for the help guys
nicko360
17
Nov 6, 2007 05:58 PM
proliant
Aug 14, 2007 02:48 PM
hman09
Feb 22, 2004 12:38 PM
2Point2EH2
Nov 22, 2003 07:32 PM
SleeprCivic
May 30, 2003 07:37 AM
