radiator support/clutch
Old Mar 29, 2006 | 12:13 PM
soon2bdropped's Avatar
Default radiator support/clutch
okay today as i was exiting out the school... the car was cold didn't let it warm up.. rev was at 2k. i forgot my car is dropped 2.75" so i was going down driveway and boom!! my lower radiator support smacked the floor... i was so mad.. it scared the **** out of me.. do u think i may have bent it sumwhere along the rails? cuz i look underneath the car and everything looks fine.. i popped hood to check if everything in place.. looks fine.. does anybody think the rad support is tough metal?
Old Mar 29, 2006 | 12:14 PM
Default Re: radiator support/clutch (soon2bdropped)
also i think my clutch needs to be replaced because.. its getting hard now to get the shifter into gear.. theres like some resistance.. but i don't get it.. clutch doesn't slip and i can take off wit no gas.. i don't get it..
Old Mar 29, 2006 | 08:08 PM
bump
Old Mar 30, 2006 | 06:37 PM
DrSelzer's Avatar
I would worry less about the thick metal support and more about the plastic bumper, hope there's no damage to that. If everything seems to be lining up good then I wouldn't worry. 2.75" drop is scary since bottoming-out can happen a lot!
As for your clutch issue, depends on how many miles you've put on it, but I would make sure that tranny fluid isn't too old and that it is at the correct level for starters.
rob_honda
Dec 29, 2007 08:33 AM
d16y8EL
15
Apr 26, 2005 02:12 PM
EcstacyRaver
Aug 8, 2003 07:30 AM
Legacy_CPA
Jan 2, 2002 07:46 PM
