97 d16y8 intake manifold Questions (sensors)
Old Mar 29, 2006 | 11:40 AM
MBlake55's Avatar
Default 97 d16y8 intake manifold Questions (sensors)
Hey im just installing my performer X manifold and i have some questions about coolant routing....
Could someone just list where the lines from the
FITV go?
IACV go?
PURGE ? (the top sensor?)
Old Mar 29, 2006 | 05:00 PM
MBlake55's Avatar
Default Re: 97 d16y8 intake manifold Questions (MBlake55)
bump
Old Mar 30, 2006 | 06:14 PM
MBlake55's Avatar
does anyone know?
Old Mar 30, 2006 | 06:33 PM
coneheadsracing's Avatar
Default Re: (MBlake55)
iacv has an in out, from what i have learned, it doesn't matter, but one line comes off the bottom of your throttle body, and the return form the iacv goes into your pipe from the water pump to your thermostat. the other valve i don't really know, cuz i don't even know what that does. But from looking at my y7, daily driver, and my y8 thats in my boosted 92, i believe there are lines running up by your intake manifold that it goes to. Sorry, don't know much bout that one. Oh, and there should be a line that comes from your intake mani, lower left corner looking at the car from the front, and that goes into your throttle body, for your iacv. Hope that helps some
Old Mar 31, 2006 | 05:02 AM
EE_Chris's Avatar
Water Hose connections:
The Air Assist Valve [2nd pic #24, 3rd pic #21] (what I'm assuming you're referring to by FITV) sits in the thermostat housing. So those aren't coolant lines coming out of it - those are vac lines. One goes to the intake pipe and one to the intake manifold.
I'm not familiar with the Performer-X, but does it have a spot to mount your stock IACV and stock throttle body? If yes, then is there a reason the stock routing of the coolant lines can't still be used?
Purge Solenoid connection:
As for the purge, just connect its output to the intake manifold so it can purge into it.
Modified by EE_Chris at 9:21 AM 3/31/2006
Modified by EE_Chris at 11:54 AM 4/3/2006
Old Apr 2, 2006 | 04:24 PM
MBlake55's Avatar
Default Re: 97 d16y8 intake manifold Questions (EE_Chris)
bump thanx guys
Old Apr 3, 2006 | 07:11 AM
MBlake55's Avatar
anyone else have any input?
Old Apr 3, 2006 | 07:54 AM
EE_Chris's Avatar
What has you stumped?
Old Apr 3, 2006 | 09:14 AM
suckawillis's Avatar
its simple. Run the right side(while looking at the motor) of the Iacv to the nipple on the water pump hose(hard metal one) and the left hose goes to the fitv(fast idle thermal valve) under the throttle body, the back nipple. The other end of the fitv(front of throttle body) runs to the nipple on the Im(Intake manifold) to the left. (small one off of the coolant hose that goes to the head). I disabled my fitv to keep the throttle body a little cooler
Old Apr 3, 2006 | 01:47 PM
MBlake55's Avatar
Default Re: 97 d16y8 intake manifold Questions (suckawillis)
thanx
Old Apr 4, 2006 | 06:43 PM
MBlake55's Avatar
def keep losing this post.........lol
EX-T
May 26, 2010 01:39 PM
4dek
Apr 12, 2008 01:29 AM
SpoonEk253
Feb 15, 2007 05:57 PM
Cheez-It
Aug 18, 2006 09:24 PM
PatrickGSR94
Apr 2, 2003 05:21 AM
