Small oil drips on crank-flywheel seal. Should I be worried?
Old Mar 29, 2006 | 11:28 AM
lechuza05's Avatar
Default Small oil drips on crank-flywheel seal. Should I be worried?
This is a picture of what the plate between the crankshaft and the flywheel looks like. There is a small oil dripping, not where the rear main gasket is, but in the center of the crankshaft. Should I do something about it or is it alright? I did use some heat to loosen the flywheel-to-crank bolts, but not much.
Thanks peeps. Hoping it's nothing to worry about!
Old Mar 29, 2006 | 01:30 PM
Rico's Avatar
While you already have the tranny off go to the dealership and buy a rear main seal. Save yourself some time and money...
Old Mar 29, 2006 | 02:21 PM
EX-T's Avatar
Default Re: (Rico)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rico &raquo;</TD></TR><TR><TD CLASS="quote">While you already have the tranny off go to the dealership and buy a rear main seal. Save yourself some time and money...</TD></TR></TABLE>
I'm with him /\ You might as well go ahead and replace the rear main while you're at it!
Old Mar 29, 2006 | 02:26 PM
Crazydave's Avatar
Default Re: (DSeriesBKilla)
The rear main is the black larger circle, not the inner one...
I could be falling from the top, collecting on the center ring, and then dripping,
Clean it off real good let it sit, give it a few rotations, and if you can see from where it's leaking...
I would think if your crank was cracked you would have already seen a more catastrophic failure.
but there is a first time for everything
Old Mar 29, 2006 | 02:32 PM
fmrprojects's Avatar
Default Re: (Crazydave)
change while its out
Old Mar 29, 2006 | 04:53 PM
lechuza05's Avatar
Default Re: Small oil drips on crank-flywheel seal. Should I be worried? (lechuza05)
Well I wiped it, turned it over, waited a few hours, no leaks, I put the new flywheel on. If it does become a problem down the road the transmission was surprisingly easy to take off, so I'm not too worried about it. Thanks for the replies!
Old Mar 30, 2006 | 07:29 AM
Crazydave's Avatar
Did you at least replace the rear main seal?
Old Mar 30, 2006 | 07:38 AM
zerovandez's Avatar
I want to replace that seal on mine before I assemble it. But that seal is tough to get off, anyone has tips on how to remove it?
Modified by zerovandez at 7:12 PM 3/30/2006
Old Mar 30, 2006 | 08:49 AM
rukawa1one's Avatar
As long as I dont have to take out any more Metal Gears
Default Re: (zerovandez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerovandez &raquo;</TD></TR><TR><TD CLASS="quote">I want to replace that seal on mine before I assemble it. But that seal is tough to get off, anyone has tips on how to remove it?
Modified by zerovandez at 5:46 PM 3/30/2006</TD></TR></TABLE>
Well since u are replacing it just get a flat head screwdriver and hammer and wedge it out. It doesnt matter if u damge the old one since u are replacing it
Old Mar 30, 2006 | 10:16 AM
zerovandez's Avatar
^^Thanks! I'll try that out!
Old Mar 30, 2006 | 10:51 AM
miahmouse's Avatar
I wouldn't be hammering anything anywhere near the seal. A hook always works for me...
Old Mar 30, 2006 | 11:57 AM
Crazydave's Avatar
Default Re: (miahmouse)
Just be careful not to hit the aluminum housing or scratch the are on which the seal sits.
It's very hard to use a hook to remove this seal.
I usually use a hammer and and a punch, and punch down on the seal
Old Apr 1, 2006 | 08:30 AM
zerovandez's Avatar
^^Yup I punched it out that way. I got a little gouge on the cover housing where the seal goes. This shouldn't be a problem right?
Old Apr 4, 2006 | 09:44 AM
Crazydave's Avatar
maybe.....
maybe not....
depends on how deep it is...
you could take a SMALL bead of silcone sealant (the grey stuff) and put it on the housing where the seal goes.
Old Apr 8, 2006 | 06:17 AM
lechuza05's Avatar
Just to clarify, I DID change the rear main seal while it was out, I just used a flathead screwdriver and some soft taps, came out fairly easily w/o scratching a thing! woohoo!
Skitso's CB7
May 5, 2011 10:22 PM
nplsdvr
18
Jun 29, 2008 04:45 PM
hondachris1994
20
Apr 9, 2007 06:22 PM
0ptimus prime
12
Jul 18, 2004 01:29 PM
