How to raise my Compression ratio B18c/B16a2
im currently runing 11.5:1 je pistons with a cometic head gasket.
the motor is a b16a2 head with a b18c1 block.
block is been bore to .20 over
i want to bring the compression around 11.7-11.8.
What should i do and where can i find a thinner head gasket.
I will also be running blox type B cams
deck the block and mill the head
LOL!!!
jk jp...a thinner head gasket would bump it up and using oversized and/or flat faced valves will work wonders
LOL!!!jk jp...a thinner head gasket would bump it up and using oversized and/or flat faced valves will work wonders
Slow_import
15
Jun 24, 2011 01:49 PM
