Lightest SOHC Stock Flywheel
Old Mar 29, 2006 | 06:36 AM
The Mista Mike's Avatar
Default Lightest SOHC Stock Flywheel
Is there a stock SOHC flywheel that is lighter than the others? I'm looking for a stock replacement and I didn't know if maybe an older generation or different model used a lighter flywheel. Anyone know?
Old Mar 29, 2006 | 06:57 AM
Default Re: Lightest SOHC Stock Flywheel (Mistamike17)
Did a bit of research and found that the following flywheels are used by the following models:
22100-PM7-L00: 90 Si, 92 Si/EX
22100-P05-000: 92-95 VX
22100-PEL-005: 93-95 Si/EX
22100-P10-000: 93-95 DX, 96-00 All
I also found that the 92 DX used two different flywheels, the 22100-P10-000 and the 22100-PEL-005. Pricing is crazy on these too:
22100-PEL-005: $228.68
22100-PM7-L00: $228.68
22100-P05-000: $228.68
22100-P10-000: $99.20
So what makes the EJ/EK (and a couple of years of DX) flywheel sooooo much cheaper? All of the autozone replacements seem to be the same, also.
Old Mar 29, 2006 | 07:03 AM
sicones's Avatar
you can get a 12lb ACT for cheaper then that
Old Mar 29, 2006 | 07:05 AM
Default Re: Lightest SOHC Stock Flywheel (sicones)
I realize that. I'm well aware of the prices of flywheels, but if I can snag a used one for resurfacing or get a new replacement from advance auto or o'reilly auto, I may just do that, especially if I can find a model that has a lighter flywheel.
Old Mar 29, 2006 | 07:24 AM
Luserkid's Avatar
From what ive seen the CX/VX is the lightest, i dont have the weights but i think i have 1 of each flywheel floating in the garage (i know for sure the CX, if you need it for sale). Ill try to take pics and get the weights later today.
Old Mar 29, 2006 | 07:33 AM
Default Re: Lightest SOHC Stock Flywheel (Luserkid)
Thank you sir, I may pick that up from you. Keep us updated if you will.
Old Mar 29, 2006 | 08:01 AM
Luserkid's Avatar
I found one of my flywheels, i think my friend has the other one in his trunk still. The one i have says H3/24/AG and weighs 15lbs. If someone else has a regular one laying around or if i could get ahold of my friend with the other wheel ill let you know the other weight.
Old Mar 29, 2006 | 08:37 AM
Do we know which one H3/24/AG is?
Old Mar 29, 2006 | 10:17 AM
schardbody's Avatar
cx/vx equals 15lbs, all others OBD1 equal 18lbs.
rice is nice
13
Apr 27, 2005 02:15 PM
Tyson
11
Feb 4, 2003 07:21 PM
MIZIKETSK
18
Nov 29, 2002 09:25 PM
Civic44
Sep 13, 2002 11:54 AM
Hybrid CRX
Jul 15, 2002 06:26 PM
