14x6" +35 offset, 2.5-3 inch drop, Will It rub??
As the topic states, I just picked up a set of 14x6inch rims with at +35 offset, My car is on a coilover suspension and will be sitting lowered up to 3", it is a 91 hatch, does anyone know if i will have to roll my fenders or not, and the tire size is 195/60r14. Thanks in advance, and yes i searched but could never find an answer for this offset and wheel size.
You'd have to just put them on and see. I would think be lowered that much, it was scrub with even a higher offset. You could also just go down in tire size to a 195/55-14 or go up with the coilovers
you will be ok, i had the same setup on a crx which has less fender area to begin with.
if you were tryin to run a 15" with a 205/50 at 35 offset u will run into problems
XX x 6 et 35 will stick out LESS than a XX x 7 et 40 (by about 3mm). you are easilly fine with anything under a 205 section as long as you keep the overall diameter the same.
right on, thanks for all the replies guys, exactly what i wanted to hear, i was almost sure they would fit but wanted to make sure, pics of them rims in a half hour
they are 14x6 JDM Creative Direction Wheels, picked them up off Streetwerkz, good seller
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx »</TD></TR><TR><TD CLASS="quote">nice wheels. what are they?
you might have to change your name to phaser if you run those tires.
LOVE2HITVTEC
Aug 10, 2005 03:28 PM
90-CRXSi
Sep 1, 2002 01:59 PM
