Putting 2 catalytic converter on????
Old Mar 28, 2006 | 09:38 PM
Khmi's Avatar
Default Putting 2 catalytic converter on????
I didnt pass smog...guy said i would need a new cat, but the one i got is new, but pretty short. But im broke, but my friend has a an extra cat. I know i will kill alot to power... but does anyone think it will help or damage the motor.
Old Mar 29, 2006 | 08:25 AM
Mavrick's Avatar
Default Re: Putting 2 catalytic converter on???? (Khmi)
cant damage the motor. can only help
Old Mar 29, 2006 | 09:50 AM
Tippyman's Avatar
It'll be alot more restrictive, but u can always take it off once u pass.
Old Mar 29, 2006 | 11:21 AM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (Tippyman)
have you changed the sparkplugs and o2 sensor? cause you might start with that before welding up another cat..
Old Mar 29, 2006 | 12:23 PM
the stock cx's Avatar
putting 2 cats will not damage the motor. but its useless to put 2. you just need one good 3-way cat from the factory or similar to factory. also you need to know what you failed at so you know if you need a new cat or not. depending on the reading. i hope that helps.
Old Mar 29, 2006 | 01:40 PM
TeamRedline89Hatch's Avatar
yeah, i failed pretty bad, put on a 3 way cat and replaced the 02 sensor, passed with ease
Old Mar 29, 2006 | 01:59 PM
Khmi's Avatar
Default Re: Putting 2 catalytic converter on???? (TeamRedline89Hatch)
o2, sparks plugs, everything is new. I have I mildly built d16z6, with a a6 pistons, and crower stage one cams, replaced everything when built motor.
I had to go to a test only smog and failed Nox, the max allowed was about 870 i was at 1700 (dont know exact number, papers its in my car). I'm koo with the smog guy. He said that most likely cat. He said that my cat looks a bit short( stock 91 si cat). He said i should get a obd-1 cat since it is made of the motor, but i dunno if he knows what he is talking about.
Old Mar 29, 2006 | 02:02 PM
BiG Chris's Avatar
if you car came with one but you have 2 and the inspector sees that, you can fail also
Old Mar 29, 2006 | 02:05 PM
Khmi's Avatar
Default Re: (BiG Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiG Chris &raquo;</TD></TR><TR><TD CLASS="quote">if you car came with one but you have 2 and the inspector sees that, you can fail also</TD></TR></TABLE>
Like i said smog guy is a friend of a friend. He saw the z6 a knew right away it was not a stock motor. But said it was ok, as long as i passed....and no he is not going to "hook me up"
Old Mar 29, 2006 | 02:10 PM
BiG Chris's Avatar
sorry i missed that detail
Old Mar 29, 2006 | 02:14 PM
Khmi's Avatar
No biggie..
ftrms
May 18, 2009 10:38 PM
asianalbutt
Jun 26, 2006 09:35 PM
mintscorpion
19
Jan 20, 2006 04:27 PM
ruiner17
Jun 12, 2004 04:23 PM
