Lost Motion Assembly
Old Apr 3, 2002 | 02:28 PM
riot's Avatar
Default Lost Motion Assembly
I am purchasing a car with an SiR B16A motor. Apparently from time to time (not so much anymore) there is a ticking coming from cyl #1. Now the seller told me that he was told it was the lost motion assembly. It will tick for a few minutes but once warm, it will go away.
This "hook tool" is pulling one out of a VTEC head just for references. There are apparently 8 total assemblies...2 for each cyl, 1 intake and 1 exhaust. Now I have read that "lack of oil" will cause these suckers to tick. You are supposed to soak them in oil, etc.
Now I can get a new one for $26 from Honda and probably install it myself. Do you think it would be worth my while to do this labor? It really doesn't look too hard, but still...will I be causing damage to anything if I don't replace the "bad one"? I figure if I do replace the "bad one" it will be a good oportunity to change the timing belt and other such things. Feedback?
-ryan
[Modified by riot, 5:30 PM 4/3/2002]
Old Apr 4, 2002 | 02:35 AM
kinesistech's Avatar
Default Re: Lost Motion Assembly (riot)
If you want to save money do it yourself, if you feel comfortable with the job. Its only 26 bucks for the part, but if your not confident with doing a valve adjustment or whatever then I wouldn't do it. Its really not hard at all, with the right tools it could take less than an hour. If it doesnt get done it wont really damage anything so I wouldnt worry about it if its tolerable. but then again its only $26.
thats my name
Old Apr 15, 2003 | 06:40 PM
MisterB's Avatar
Default Re: Lost Motion Assembly (kinesistech)
mine makes the ticking too but how were you able to determine what cylinder it was comming from?
Old Apr 15, 2003 | 07:26 PM
GZERO's Avatar
sorry for this question, but what is the lost motion assembly? (english is my second language, and i can't find the translation anywhere.
Old Apr 15, 2003 | 07:29 PM
RCautoworks's Avatar
Default Re: Lost Motion Assembly (cl4show)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cl4show &raquo;</TD></TR><TR><TD CLASS="quote">mine makes the ticking too but how were you able to determine what cylinder it was comming from? </TD></TR></TABLE>
Hold a screw driver up to the valve cover and the listen to the one end, you will be able to tell where its coming from.
Old Apr 15, 2003 | 07:30 PM
mmuller's Avatar
Mad Scientist
Default Re: Lost Motion Assembly (GZERO)
lost motion assembly is what keeps the middle rocker from flapping around when not in use.
Old Apr 15, 2003 | 07:40 PM
GZERO's Avatar
Default Re: Lost Motion Assembly (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">lost motion assembly is what keeps the middle rocker from flapping around when not in use.</TD></TR></TABLE>
Thank you. I haven't touch a VTEC head YET!! that's why i didn't knew.
Old Apr 15, 2003 | 09:01 PM
Rob Dizzle's Avatar
LMA's take the energy from when the rockers go from low to high lobe (vtec activation)
I know at least one guy on the board here most likely broke a cam shaft because his lma's on his gsr werent strong enought to handle his either toda or jun cams.
put the time and lil money into getting some new lma's
your mistake could cost the price of a new head and bottom end when your valves drop into your cylinder at 8kRPM
Old Apr 15, 2003 | 09:07 PM
MisterB's Avatar
Default Re: Lost Motion Assembly (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Hold a screw driver up to the valve cover and the listen to the one end, you will be able to tell where its coming from.</TD></TR></TABLE>
i did that and they all sounded the same... i guess ill just have change them all out
Old Apr 15, 2003 | 11:05 PM
civicsitek GanGsTa's Avatar
you said it goes away after the car warms up? Id leave it alone, not worth the hassle if you dont know exactly what is causing the problem, it may just need a valve adjustment. If you are going to replace them then step up to the ITR LMA's.
Old Apr 15, 2003 | 11:06 PM
Default Re: Lost Motion Assembly (civicsitek)
ps you dont need that hook tool, just 2 fingers that can grab a small object
mvp97gsr
Aug 23, 2008 10:28 AM
Jeffrey9
Oct 24, 2005 02:25 AM
stealth_prelude
Aug 30, 2005 10:47 AM
lilxvtecxpwr
Dec 7, 2004 07:57 AM
jdm4life
Oct 23, 2003 01:40 PM
