how do you take a b16 trnny apart
Old Mar 28, 2006 | 05:50 PM
silentvoice19's Avatar
Default how do you take a b16 trnny apart
like the title says how do you remove the bell housing from the gear box??? mine seems to be jammed unless there is something im missing
Old Mar 28, 2006 | 06:07 PM
so lazy's Avatar
Default Re: how do you take a b16 trnny apart (silentvoice19)
theres a PIN where the 1/2in ratchet fits into... take that bolt out and you'll see what i'm talking about...
Suggestion not being a *** or anything dont take it the wrong way... If I didnt know how to take out the case i wouldn't want to take it apart unless you have money to buy another one..
GOOD LUCK!
Old Mar 29, 2006 | 09:10 AM
Default Re: how do you take a b16 trnny apart (dc2-guy)
its a spare im fiddlin around with it. the 1/2 in ratchet on the end right??
Old Mar 29, 2006 | 02:02 PM
so lazy's Avatar
Yeah 1/2 inch man.. there should be a SNAP RING in there just snap that ring out and there you go pull off that case.. good luck..
Old Mar 29, 2006 | 02:09 PM
BMaDOHC's Avatar
theres also a couple of twelve mm bolts with little ***** at the end, you should probably take them out too.
Old Mar 29, 2006 | 05:18 PM
Default Re: how do you take a b16 trnny apart (BMaDOHC)
ive taken everything off except that 1/2" bolt
dseriesboulder
Mar 24, 2014 01:31 PM
arren123
May 4, 2011 02:16 PM
generaltao
14
Apr 16, 2009 07:03 PM
Spoon_Si-R
20
Jan 3, 2007 03:25 PM
Shocka1998LX
Aug 22, 2004 05:11 PM
