Turn signal issues with AC gone
To keep this simple, I took out the AC system and heater as well recently. Soon after unplugging all the wires under the dash and removing all that crap that didnt work anyways, I noticed that the turn signals didnt work. I jumped a wire in somewhere and got the turn signals and hazards to work again, but only in the back. Before it wouldnt even turn on at all. The signals only work when the car is running now which is strange. Still, now the running lights work up front on the corners, yet, the turn signals don't! What the hell is going on here and what color wires do I need to mess with under there? I could use any help available as long as you know what youre talking about.
u forgot to plug in the hazard button underneth the panel. if the hazard button is unpluged the turn signals wont work or the hazard either
Just so you know, all the stuff related to the heating and ac under the passenger side dash is completely removed, there are wiring harness clips hanging all over the place since theres nowhere to plug them in now. The hazards work, and the corner lights up front work, WHEN THE ENGINE IS ON, but not when off. The only lights that dont work are the turn signals up front, which means when the hazards are on, the ones up front still dont work. Grounds are fine. Everything under the hood and all the fuses ALL the fuses the car HAS are straight. I believe a wire or maybe more than one under the dash has something to do with it.
eschavez6
Honda Civic (2001 - 2005)
Aug 7, 2018 08:16 AM
