idle bounching
Old Mar 28, 2006 | 04:39 PM
d16civic111's Avatar
Default idle bounching
i have a 00 civic ex with a d16y8 i replaced the stock motor with one with less miles and i got one out of a automatic not knowing that the heads and intake are smaller than a manual one. now it idles funny at 1800 to 2100 rpm. the intake on a auto car doesnt have the ivac motor what can i do to fix it with out swaping heads from the other motor. thanks
Old Mar 29, 2006 | 06:45 PM
Default Re: idle bounching (d16civic111)
any one have ne ideas or should i just swap head?
Old Mar 29, 2006 | 07:59 PM
JDM-Forti's Avatar
those it just idle ruff at neutral or any time that car is not moving?
Old Mar 29, 2006 | 09:24 PM
johnecon2001's Avatar
Uhh.. all that stuff should be the same manual to auto. The only thing that differs is clutch + tranny vs tranny.
The bouncing idle probably is the TPS sensor. It probably is reading at too high of an ohm load.
Old Mar 29, 2006 | 10:07 PM
Out of every
search is your friend pass it on
Old Mar 30, 2006 | 02:41 AM
Syndacate's Avatar
maybe O2 or something...iono...doubt it's the TPS though..
Old Mar 30, 2006 | 03:46 AM
tuned2's Avatar
possibly fast idle thermal valve.
Old Mar 30, 2006 | 04:53 AM
EE_Chris's Avatar
Auto Y8's used a 3-wire IACV that is mounted on the throttle body. If you want to use a 2-wire IACV, modify the intake manifold (yes, it can be done since 5-spd intake manifolds started life as an auto intake manifold) and mount one up. Get a 5-spd Y8 throttle body to round out the package.
You have a vacuum leak, which is being caused by the IACV. 3-wire and 2-wire IACV's aren't constructed the same nor operate the same. When you unplug a 2-wire IACV, it's suppose to close down and seal off the air passage. 3-wire IACV's use a rotary type of mechanism which never closes down once unplugged, which means it's always allowing air to run through it. And setting the idle for a motor that uses one vs the other is also different.
Old Mar 30, 2006 | 08:16 AM
Default Re: idle bounching (EE_Chris)
thanks for the info
Old Apr 6, 2006 | 09:42 AM
tuned2's Avatar
i just reread the first post. at first i thought it said you had a 94. anyway def. an IAC issue...
jrenna
Jan 20, 2013 06:29 PM
Maple50175
Honda Civic (2001 - 2005)
Nov 18, 2010 05:06 PM
DailyDriverCivic
Mar 13, 2008 07:52 PM
chahsiubow
Jun 6, 2004 07:26 AM
rrei
Oct 14, 2002 07:48 PM
