spark plugs question
Old Mar 28, 2006 | 04:37 PM
ekVtecPower's Avatar
Default spark plugs question
when do u regarely change ur spark plugs because my hatch wont start, it makes a BIG CLICK sound when i try and turn the on..any i checked my spark plugs and their really rusty.. that that have to do with the car not starting?? plz help! thanks
Old Mar 28, 2006 | 04:45 PM
sohc_coupe24's Avatar
does the crank even turn over?
Old Mar 28, 2006 | 04:48 PM
Default Re: (sohc_coupe24)
No, its just that loud click noise.
Old Mar 28, 2006 | 04:52 PM
the clicking could be ur fuel pump
Old Mar 28, 2006 | 04:53 PM
its not click more than once, its just one loud click. no more than one.
Old Mar 28, 2006 | 04:56 PM
i don't know...but i would say u might want the motor to crank first. Then check if its getting fuel and spark (anyone correct me if i'm wrong)
Old Mar 28, 2006 | 04:58 PM
HELP!! plz
Old Mar 28, 2006 | 05:05 PM
EGchicSOHC's Avatar
Default Re: (ekVtecPower)
did you check your battery or your starter? it sounds like you have a dead battery.
Old Mar 28, 2006 | 05:07 PM
frankenstienEk's Avatar
when you turn the key on the on postion and it is clicking it could be your starter. Because i think a similar problem and it ended up being a starter
Old Mar 28, 2006 | 05:20 PM
Default Re: (frankenstienEk)
not the starter, because i took it out and took it to get it checked and they said it was good.
Old Mar 28, 2006 | 05:32 PM
posite's Avatar
If your engine is not even turning over its a dead battery or starter... or it sounds like it could be a lose terminal wire on the battery or bad ground.
Old Mar 28, 2006 | 05:35 PM
Default Re: (posite)
its not that dudee.. battery already checked and starter also, the terminal seems to be fine.. dont know y its not turning over tho........ really wierd!
Old Mar 28, 2006 | 05:36 PM
tominos's Avatar
so if you don't hear any cranking, just clicking. it's most likely a dead battery. do your lights look dim?
Old Mar 28, 2006 | 06:21 PM
iBrandon's Avatar
Default Re: (tominos)
no man, i told you all its not the starter or battery, im thinkin its the spark plugs ?? but not quite sure, because when i turn the key to the ignition it just makes a click sound.. battery and starter look fine. so... Spark plugs u think??
Old Mar 28, 2006 | 06:23 PM
Default Re: (iBrandon)
sorry, that was me above this thread.
Old Mar 28, 2006 | 06:24 PM
CardDealer's Avatar
Banned
Modified by CardDealer at 2:45 PM 11/16/2006
Old Mar 28, 2006 | 06:26 PM
john666's Avatar
change the plugs if you think thats the problem but even with lets say 1 spark plug not plugged in the car would start. just wouldnt run right..
Old Mar 28, 2006 | 06:56 PM
Default Re: (john666)
John666 is right
Old Mar 30, 2006 | 09:01 AM
tominos's Avatar
just because they look good doesn't mean they are good. test them out.
Old Apr 1, 2006 | 08:32 PM
Default Re: spark plugs question (ekVtecPower)
It sounds like your starter went out. try and push start it and see what happends!
Old Apr 1, 2006 | 10:31 PM
souljah_jon's Avatar
Default Re: spark plugs question (1jdmda9)
man its not your spark plugs.. you can run your car with i think just 2 spark plugs.. go ask professinal help
Old Apr 1, 2006 | 10:35 PM
BALLIN H22 EK's Avatar
Default Re: spark plugs question (souljah_jon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by souljah_jon &raquo;</TD></TR><TR><TD CLASS="quote">man its not your spark plugs.. you can run your car with i think just 2 spark plugs.. go ask professinal help</TD></TR></TABLE>
haha soo true ive been running on 2 good sparkplugs for a day now...
its ur starter or battery swap them out i bet the car will start
Type_R_Lover
Jan 19, 2010 06:19 PM
easyFOsheezy
Jan 28, 2006 12:25 AM
SloCrxDx91
12
Jan 22, 2006 07:21 AM
chito_zan
34
Aug 23, 2004 10:56 PM
sirb18a
Feb 4, 2004 10:44 AM
