Will an ls throttle body fit on an A6 intake manifold or will I need the y8 or z6???
Help a fellow civic owner out.I can get a deal on a y8 if thats what I need cause right now I got an a6.Thanks
it will fit on the a6. a b series tb will fit on most d series intake manifolds. just need to bore out the manifold so its the same size as the tb or else you just wasted time for nothing.
Yes they are different, I thought they were the same but there was a thread about this a week or so ago. The MAP is different too, non-OBD0 manis have it on the throttle body, OBD0 on the firewall.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest »</TD></TR><TR><TD CLASS="quote">Yes they are different, I thought they were the same but there was a thread about this a week or so ago. The MAP is different too, non-OBD0 manis have it on the throttle body, OBD0 on the firewall.</TD></TR></TABLE>
Doesn't matter, you can use either map sensor, it'll work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downest »</TD></TR><TR><TD CLASS="quote">No extra nipple for it on OBD1 manis though, unless you ditch the canister, which should be done anyway.</TD></TR></TABLE>
Can you go into a little more detail???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm »</TD></TR><TR><TD CLASS="quote">IIRC B-series will not fit OBD0 intake manifold though. I'm pretty sure the A6 mani has a different mounting flange than a Y8.</TD></TR></TABLE> CORRECT!
92-00 Motors (D/B/H) All share the same mounting flange for TB. Before I get yelled at, 90-91 B TBs also share the same flange.
Is there anyway I can bore out a couple of the mounting holes?? I would imagine as long as it's pulled tight to the manifold it wouldn't really matter,anybody done this????
Again I ask:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Screaming »</TD></TR><TR><TD CLASS="quote"> Is there anyway I can bore out a couple of the mounting holes?? I would imagine as long as it's pulled tight to the manifold it wouldn't really matter,anybody done this????</TD></TR></TABLE>
puertoricanboy90
66
Jan 15, 2011 06:31 PM
