DC5R steering wheel on a DC2 possible?
Old Mar 28, 2006 | 04:09 PM
DB8ITR's Avatar
Default DC5R steering wheel on a DC2 possible?
I'm getting a sweet deal on this wheel and I'm not sure if it will fit. Instinct lately tells me no lol.
http://www.jhpusa.com/catalog/...77d46
Old Mar 28, 2006 | 04:21 PM
Alexander's Avatar
Default Re: DC5R steering wheel on a DC2 possible? (4DoorJDMITR)
There must be a way.. Definately a sweet steering wheel
Old Mar 28, 2006 | 04:30 PM
Comp97GSR's Avatar
The only way I can see is to modify the hub. I would cut the splined part of the hubs off and weld the DC2 splines to the DC5 wheel. But what do I know, I think outside the box.
Old Mar 28, 2006 | 04:32 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
Default Re: DC5R steering wheel on a DC2 possible? (Comp97GSR)
man, every once in a while i think about getting one of those...
as alexander said, its a sweet steering wheel
Old Mar 28, 2006 | 04:36 PM
Comp97GSR's Avatar
Here, like this.
Old Mar 28, 2006 | 04:38 PM
DB8ITR's Avatar
Not a bad idea.
Old Mar 28, 2006 | 04:39 PM
Mugen_DC2R's Avatar
yup, i know 100% that the thing fit, but sorry i don't know how. I saw alot of DC 2 using this DC5 steering wheel in Hong Kong. So there must be a way.
Old Mar 28, 2006 | 08:18 PM
IGGY's Avatar
I think you have to replace the steering column with one of a early model civic.
Old Mar 28, 2006 | 08:59 PM
jdm2teg's Avatar
Default Re: (IGGY)
i have the 05 rsx steering wheel and i tried to put it on my dc2 and it didnt fit. i think it will fit 96+ civic because my friend has a s2k steering wheel on his civic and i tried to put that on my car and it didnt fit. so may be if you switch the integra steering colum with civic, it might work. but i am not 100% sure.
Old Mar 28, 2006 | 09:14 PM
nautica_t's Avatar
Default Re: (jdm2teg)
i believe that is the only way as it was done in a search that the only way is to get an ek (96-00) steering column to mate the dc5 steering wheel.
i'd love to have that wheel myself as well or even ep3 (ctr) wheel.
Old Mar 29, 2006 | 04:48 AM
George Knighton's Avatar
H-T Order of Merit
Default Re: (nautica_t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nautica_t &raquo;</TD></TR><TR><TD CLASS="quote">i believe that is the only way as it was done in a search that the only way is to get an ek (96-00) steering column....</TD></TR></TABLE>
Can the hub on the steering wheel be changed?
The apocryphal eBay personality JAPAndy once found me an unusual Momo Honda Access wheel that I wanted to put on my DC2, and the only one he could find required him to switch the hub with one from some kind of Civic.
It must have been easy because he didn't charge for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DoorJDMITR &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.jhpusa.com/catalog/...77d46</TD></TR></TABLE>
Don't blow up the airbag!!
When putting the DC5 ITR wheel on a DC5 Type S or EP3 Si, you have to switch the deployment relay. I have no idea how you'd get that to work w/a DC2, or even if you can.
Also be aware, if you have never driven a DC5 or EP3, that the things that attract you to these wheels, namely the size and the easy-to-find palm bolsters, can make the car very annoying if the alignment is off and the wheel is even slightly off centre.
Old Mar 29, 2006 | 08:51 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (George Knighton)
The hubs should be interchangeable like the CTR and DC2ITR, they might intercahnge with each other DC2 hub verse DC5 hub, but I have no clue. I got scammed and was sold a CTR wheel thinking it was an ITR wheel, needless to say I had to find a ITR hub.
Old Mar 29, 2006 | 09:10 AM
YumVTEC's Avatar
Default Re: (walker111)
you need an EK steering column then you can use the DC5 steering wheel. unless you want to cut off the splined section of your column and weld on that of an EK or another DC5.
Old Mar 29, 2006 | 09:51 AM
-Infinity-'s Avatar
Default Re: (YumVTEC)
Here is an idea. Buy that wheel and a non srs wheel for a dc2. Swap the hubs. And sell the non srs wheel as a CTR wheel. You could even make a buck considering the non srs CTR wheel is hard to come by. Switching steering columns is just crazy.
Old Mar 29, 2006 | 10:18 AM
cool guy name
Default Re: (-Infinity-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Infinity- &raquo;</TD></TR><TR><TD CLASS="quote">Here is an idea. Buy that wheel and a non srs wheel for a dc2. Swap the hubs. And sell the non srs wheel as a CTR wheel. You could even make a buck considering the non srs CTR wheel is hard to come by. Switching steering columns is just crazy.</TD></TR></TABLE>
That's if the hubs are interchangeable between the DC2 and DC5.
Old Mar 29, 2006 | 05:01 PM
itr1244's Avatar
damn 599 for that ****
Old Mar 29, 2006 | 07:25 PM
nautica_t's Avatar
Default Re: (itr1244)
yeah the other alternative is to cut the stock dc2 hub and re-weld it to the dc5 hub.
hey mr. knighton i believe you don't have to do anything to the airbag itself on the dc2 and jdm dc5/ep3 steering wheel due to its single stage airbag. i believe the usdm counterpart is dual stage and thats the reasoning behind it.
i remember reading this on a rsx board. but i could be wrong so dont' quote me on it.
Old Mar 30, 2006 | 03:44 AM
cool guy name
The only problem with welding the USDM to the JDM is that the JDM hub is cast. I'm not too familiar with welding, but I dont think you can weld cast? Someone correct me if I'm wrong. You could use JB weld but it doesnt hold up that well.....
Ask me how I know
Old Mar 30, 2006 | 03:47 AM
itr1244's Avatar
cast ... cast what??
aluminum?
if it is aluminum.. it's gonna be hard to weld but .. there is a way. i think
Old Mar 30, 2006 | 04:06 AM
Chubz's Avatar
would this steering wheel be an easy swap on a s2k?, id rather have that wheel than my stock wheel
Old Mar 30, 2006 | 04:09 AM
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">cast ... cast what??
aluminum?
if it is aluminum.. it's gonna be hard to weld but .. there is a way. i think</TD></TR></TABLE>
Yes I think aluminum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chubzilla &raquo;</TD></TR><TR><TD CLASS="quote">would this steering wheel be an easy swap on a s2k?, id rather have that wheel than my stock wheel</TD></TR></TABLE>
It would bolt right up. But I would research what GK was talking about before you attempt something like that.
Old Mar 30, 2006 | 04:21 AM
Chubz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
It would bolt right up. But I would research what GK was talking about before you attempt something like that.</TD></TR></TABLE>
i just searched s2ki, they bolt up fine with no problems
Old Mar 30, 2006 | 05:46 AM
Luder94's Avatar
Default Re: (Chubzilla)
The wheel hub will bolt up right onto the s2000 shaft, however, I'd very careful with plugging up the airbag with the harness that comes off the JDM airbag/steering wheel!
Old Mar 30, 2006 | 08:54 AM
DC2 to AP2's Avatar
Default Re: (Luder94)
use a ek steering coloumn and be done with it.
Old Apr 7, 2006 | 12:07 AM
OUT OF ORDER ROB's Avatar
Default Re: (imola-red dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imola-red dc2 &raquo;</TD></TR><TR><TD CLASS="quote">use a ek steering coloumn and be done with it.</TD></TR></TABLE>
NorthernXposure
Jan 2, 2006 03:11 PM
Integra21
Jun 24, 2005 03:22 PM
itr501
Jun 20, 2002 04:38 PM
