cheap cam install/uninstall in the bay area
Old Apr 3, 2002 | 01:55 PM
comptechgsr's Avatar
Default cheap cam install/uninstall in the bay area
might have to remove my cams in a month and a half due to carb...
might even sell them...
where and around how much?
Old Apr 3, 2002 | 01:57 PM
Austin's Avatar
Default Re: cheap cam install/uninstall in the bay area (comptechgsr)
Ouch...doesn't sound good...you'll also have to remove the skunk manifold and the itr AEM CAI...
Old Apr 3, 2002 | 02:04 PM
StinkyTofu's Avatar
Default Re: cheap cam install/uninstall in the bay area (Austin)
If you're just removing your cams it shouldn't cost more than 120 dollars. I don't see why you would have to take your intake manifold off if you're keeping the head on. You're gonna sell your cams because of carb??
Old Apr 3, 2002 | 02:08 PM
reefer_bob's Avatar
What kind of cams?
Old Apr 3, 2002 | 02:13 PM
Austin's Avatar
Default Re: cheap cam install/uninstall in the bay area (StinkyTofu)
He has a Skunk2 intake manifold...and he's having to take a trip to go and see the CARB referee...which means that if it doesn't have a CARB number for it, or if you've made any modifications whatsoever with non-CARB approved parts, chances are that you're screwed and will fail the test.
Old Apr 3, 2002 | 02:15 PM
xtrafastcivic's Avatar
Default Re: cheap cam install/uninstall in the bay area (reefer_bob)
If your are just removing the cams and not removing vavle springs are anything it's pretty easy. most shops charge like 200 dollars
Old Apr 3, 2002 | 02:23 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: cheap cam install/uninstall in the bay area (XtraFastCRX)
how did you get nabbed?
Old Apr 3, 2002 | 03:47 PM
Default Re: cheap cam install/uninstall in the bay area (Ross)
pulled over for no front license plate, clear corners, and illegal exhaust
Old Apr 3, 2002 | 04:11 PM
SamC's Avatar
and you need to see refree for that? I thought those are fix-it tickets?
Old Apr 3, 2002 | 05:00 PM
STOLEN - ITR 98-0652's Avatar
Wrench it yourself.
Not only is it "free" but you gain valuable experience for when you put your non-stock cams back in...
F the CARB.
Old Apr 3, 2002 | 05:13 PM
Rhetoric's Avatar
Default Re: cheap cam install/uninstall in the bay area (ITR 98-0652)
Give Jeff an IM at Jeff652.
Old Apr 3, 2002 | 05:16 PM
Art Vandeleigh's Avatar
Default Re: cheap cam install/uninstall in the bay area (G S R)
yeah do it yourself, its not that hard if you take your time and becareful. its all in the helms or on cspeed or bseries.net
carb
Old Apr 3, 2002 | 10:32 PM
Default Re: cheap cam install/uninstall in the bay area (SamC)
yeah, DICK *** COP...made me see the ref jus for illegal exhaust
Old Apr 3, 2002 | 10:37 PM
dc24me's Avatar
Weren't you the one who was trying to figure out whether or not you should bring your car up to Boston? You should, because you won't have to deal with the this **** here. You can't even fully enjoy it. And even if you had the car registered with MA plates, you won't have a problem in when you're back in Cali.
Old Apr 3, 2002 | 10:38 PM
Stock@$$GSR's Avatar
What city is the jackass porker from??? Going to a ref for exhaust? That's ruff man. What exhaust were you running? Was it loud as **** or something?
Old Apr 4, 2002 | 07:18 AM
TypeRdude's Avatar
Default Re: cheap cam install/uninstall in the bay area (Stock@$$GSR)
We'll R+R them for you in Livermore (about 40 miles from you) for $260
Call 925-371-7222 10am-7pm to make an appointment
Old Apr 4, 2002 | 07:25 AM
jeff652's Avatar
$100, with valve adjustment and timing check . . .
Old Apr 4, 2002 | 07:29 AM
Austin's Avatar
Default Re: cheap cam install/uninstall in the bay area (jeff652)
Damn Jeff...Dino, have Jeff do it...I trust him, and can give good references for him...he's a great guy.
Austin
P.S. Jeff...parts ship this week
tempsohc
Nov 12, 2006 10:29 PM
jdm ek9 101
Sep 13, 2006 04:46 PM
sharkey65a
Jan 7, 2003 12:55 PM
masterxfob
Aug 30, 2001 08:18 AM
