Pics of my custom brake lines
So I'm doing a wire tuck, shaving the firewall, relocating the fuse box and battery in the cabin, and doing some custom brake lines to complete the project. I'm almost done with the brake lines, just have to cut and flare them into the proportioning valve. Let me know what you think.
sweet.
what about running the passenger front on the other side of the firewall (behind the dash) and then entering the engine bay where it turns left and then a straight shot to the existing grommet at the wheel well? just thinking out loud.
greg, who has to (one way or another) re-run every brake line on his crx, and likes where this thread is going.
Thanks for the kind words fellas. I got all the lines at O'Reilly auto parts here in town. Its a local auto parts store so I'm sure an Autozone or PepBoys carries them to. They're 3/16" lines and they come with the fittings on them. I just moved the OEM proportioning valve in the cabin so it will be under the dash out of sight and out of mind. This is all a real bitch to do with bending all the lines and trying to get everything to fit right. Its all pretty looking but thats just because I had time to spare the real purpose for all this is to get everything out of the way so I can focus on my engine and make one sick street setup, all-motor of course
These are the connections to the proportioning valve under the dash. I'm almost done I've got one of the last 2 connected just haven't taken a pic yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b.d.racing »</TD></TR><TR><TD CLASS="quote">Local auto parts store will carry a tubing bender which is what I use. It has handles like a wrench. </TD></TR></TABLE>
Those lines are actually really easy to bend by hand also.
It looks to me like the majority of your bends were done by hand, no?
Getting a perfect double flare with one of the flaring tools you can buy over the counter at your local parts store is nearly impossible.
I had to borrow my friends $300 flaring kit before I could get my flares to seal properly when running new ABS hardlines.
What I ended up doing later on in my project was measuring approximately how long each line needed to be and then buying the lines that are already flared with fittings on them. They come in like 6" increments and make the project infinitely easier. It's only a few bucks for each line, but it's worth it IMO.
Hondatuner88
Welding / Fabrication
13
Jan 11, 2008 06:38 PM
